Nagra Reference Phono Cartridge
Hello! no news?
Hello! no news?
Sorry what are you looking for? If it's how do I like the cartridge, it's fantastic. My #1 cartridge now. Great resolution, body, extension, does it all...
Same feeling as you! Do you still use 180 loading? With my Esoteric pre phono, 300 seems best , but its difficult for me to choose between 100, 200 and 300
Reactions: Zeotrope
Yes, I have settled on 180. But like you I could live with a higher or lower setting. I am going to revisit loading soon, I guess I have about 50 hours on this cartridge now. The sheer amount of resolution, portrayed so naturally, I just love. While super hi Rez, it's relaxed, easy, pulls me in...
Reactions: Zeotrope
I agree. I am now looking for a new pre phono ( my Esoteric E2 is only 12 months old !). CH Precision P1 is probably very good, but the new Nagra HD could be better, as a perfect fit with the cartridge ( hope it will be in Munich)
I heard the HD phono will be in Munich. They have apparently finished the prototype and sourcing parts for a production run soon. And I suspect the two (cartridge and phono stage) were developed together. I love my Nagra Classic Phono/Classic PSU. It's something else to consider...although I will likely upgrade to HD Phono soon...
Reactions: Robert Young
I will soon upgrade my Nagra HD pre ( I got mine in October 2018, a few months before power supply upgrade). Did you upgrade your pre, or did you buy one with the upgrade?
I upgraded my HD Pre about a year or two ago. I also added the input balancing transformers for my dCS Vivaldi DAC. Both were nice improvements on a already fantastic preamp.
Thank you! I was hesitating as I have to sent it to Switzerland, but if its a real improvement I will do it
It's real
It's real. You won't regret it (other than being apart from it for a week or two!)
About pre phono, your Nagra Classic is a tube preamp, as the HD pre phono will be. It is probably a better fit with the high resolution of the cartridge than a CH Precision , which might be too " neutral" . Is it your feeling too?
I haven't heard the CH Precision, but I would suspect that as well, certainly something to listen for in a demo. With my Classic Phono, I have been able to nudge around the sound some with tube choices. It came stock with tightly matched Genelex tubes. Which are quite good for the money. I have also tried Telefunkens (a little to much sparkle for me), Amperex (love these great blend of a touch of sweetness, but very linear and excellent extremes) and now I have Mullards in, which seem to be the lowest in noise, but a touch more sweet than the Amperex-this seems a good match with the Nagra cartridge. In my HD Pre, it came from the factory with NOS Mullards, but I have the Amperex tubes in it now which I like best.
This is a little like loading settings on the phono stage, they all sound good, but each combination has its merits. It's like do you want a merlot or cab with dinner...both are good, but pair better with certain things.
The CH in current mode is actually not "too neutral" it is very dynamic but still stays sweet. HOWEVER it does not like high internal impedance carts, with these it surely can sound cold and forced to some degree. I have no idea where the Nagra's is in terms of internal impedance. I'm interested though because EMT was mentioned and I have an EMT "Banana" arm and am looking for a cartridge to go with it. I just got the SME mount slider to adjust for the overhang of non EMT carts :)
IMO it would be a waste to have a P1 and not employ it's Current Drive input. It is IME better that its I/V.
Just my two cents :)
Thank you Jack. There are two Nagra cartridges, one with an internal impedance of 4 ohms and an output of 0.30 mv, and one with an internal impedance of 6 ohms and an output of 0.45 mv ( mine)
Ooooh that is right in the P1's happy range. For Jfrech and I though our GFS don't play too well with P1s :(
What is GFS?
Clearaudio Gold Finger Statements
Rotatoubib, I moved up to my 270 loading card. Brought out more body and fleshed things out better, lil less zip. I may move up to 470 card today but that maybe to much of a good thing. Could be my cartridge is breaking in some, guessing it has 70 hours on it now. Also could be my new table and a preference thing...
