Or naked girls !Just for the record, and so casual WBF viewers are not misinformed, I do not censor anybody. I am not involved in moderation.
(I do have a hair trigger on the "Report" button if any post has the slightest whiff of politics.)
Yes, because this is a classy, family-oriented, non-misogynistic website!Or naked girls !![]()
Recordings and stereos indeed have intentionality…are they not made by humans with specific goals for recording and replaying what was originally performed? They can deliberately affect what most people will perceive…it’s not effects happen…they are engineered to deliver those effects.
Tim, I agree with your first sentence. Could you expand on what you mean by the second one? Do you mean they are simply inanimate objects with no volition?
I thought many felt a horn is more detailed and transparent. Relaxed is difficult to define with stereo.I think that depends a lot on the horn! A well designed horn is a very low distortion device! If you have the right one they are very transparent, very relaxed and detailed, ceding nothing to regular dynamic drivers.
I think the raison d'être of horns is life-like dynamics and "jump factor."
I think the raison d'être of horns was the existing low power amplifiers and the need to fill the space of large movie theaters with convincing sound.
If you talk about speakers you need to talk about amps.
The amps in theatres were Altec Lansing 1570B with 811 tubes in push pull. 130 watts or so.I think the raison d'être of horns was the existing low power amplifiers and the need to fill the space of large movie theaters with convincing sound.
The best horns do many things well beyond just dynamics and jump factor. They can present a very natural listening experience.
I am not commenting on the sensitivity of the speakers. I had one of those amps. Tom Tutay rebuilt it. I was of the understanding that they came from movie theaters and ran the Altec Lansing speaker. You do have 2 x 12 inch drivers in the bass cabinet. And you're pressurizing a theatre. Not someones listening room.
'Relaxed' is a lack of higher ordered harmonic distortion (IOW its inaudible) and also a lack of weird room problems (like slap echo) or breakups in the loudspeaker, lack of early reflections caused by side walls and so on. IOW, does not sound 'loud' even if playing +95dB.I thought many felt a horn is more detailed and transparent. Relaxed is difficult to define with stereo.
Historically horns were the thing because even in the age of tubes, tube amplifier power was expensive. So you had to make the most of it you could.I think the raison d'être of horns was the existing low power amplifiers and the need to fill the space of large movie theaters with convincing sound.
FWIW before Altec made amplifiers theaters were powered by Western Electric amps, some of which were SETs (211s if memory serves). The horns WE made for that application are something to behold and looking like they had something in common with a Klein bottle.I am not disagreeing Peter. I am only saying, the horns that were in theatres, from what I understand were driven by matching amps by Altec Lansing. Those amps were many times a 1570B. A PP amp.
In the day when these speakers were used in a movie theatre, how many speakers were there????2???
In a moderns movie theatre, there are speakers all around the room. There are thousands of watts of amps. And some sort of mixing board or control system. 130 watts in not much power. Especially when you consider the room is how big? Were talking a room with maybe 350 seats more of less. Not you living room.
Yes, if the driver is hardly moving its a lot harder for it to distort. Diaphragms can break up despite that, causing distortion. That's the one thing that can be obnoxious on a horn midrange. In the old days this was common (the aluminum diaphragm of the Altec horns has this problem at higher levels). My horns use a beryllium diaphragm which has its first break up at about 35KHz, so its pretty smooth.The main advantage of horns, as I understand it, is high sensitivity, as the compression drivers couple well to the surrounding air, and what this means is that for a same SPL, there is less membrane movement and less distortion/higher resolution.
Today, SETs are just one among many other options. I would love, for example, to listen to my poweramp with horns - I would bet the low distortion of the pair would be pretty amazing - but that will be probably for another lifetime.
Some of the Aries Cerats are horns although to be clear, a waveguide is considered a horn.What constitutes a horn? What about the Aries Cerat speaker. That looks to be a 6 or 8 inch driver in a transmission line. Is that a horn.
What about the Altec with the 1 to 2 x 12 inch drivers in a folded cabinet.
What about a single 12 in a ported box with a multicell on top?
What about a 12" open baffle driver set behind a 3" thick slab with a flared face?
How much material has to be in front of the driver to be considered a horn. And when does the port become a horn. As in the transmission line speaker. The large flared port appears to be a horn. But the sound is very directional from the cone driver in the face of the speaker. So is that a horn, or a speaker with a long port to extend the bass frequency.
Objective? In which way?
