"I did some looking at my main system, the Sugden mono blocks etc. I went to install the master fuse in my DAC, and to my surprise there was a purple fuse in it? I don’t recall changing that?" Without question I have found that failing to recall I have already Modded equipment -in some fashion or another- is one of the first signs of insanity. My father used to say "what the hell, as long as you are as happy as though you were in your right mind, there is no harm.
I have now become somewhat interested in SR's Master Fuse. From the little I have read about it the theory or sales pitch for the fuse seems to be that properly placed you only need one fuse per system. That seems like a very ambitious task for one fuse and following your post you also don't seem to buy that approach. Can you describe what the difference is you have noticed with this fuse -other than the price- over other fuses in your system. More specifically, do you believe this fuse is really worth the $500.00++ bucks compared to the paultry $350.00 Pink fuse for example?
