For the 3.3 dip switches are only needed to set gain, damping, and for flat or internal-applied RIAA signal output. All else is now done via toggle switches on the front of the bottom panelThanks agin allvinyl, I know I am a bit fussy but the other thing with the Lino C is dip switches. I am used to the controls upfront.
One of these days I will find what I want, the Rega is the front runner for now.
Yes I only need it while setting up then I don’t touch it again, but while setting up I can change it on the fly and hear the effect immediately. None of these turning it off adjusting dip switches on the back, then having to remember what it sounded like while listening to the new setting.Uaually once gain and load are dialed in you wouldn’t need the front control. I get that you want what you want. Both my phonostages have loading on the back side, old school.
The idea that the Aura was designed solely for the Rega cartridges and tonearms is complete nonsense. How do you even design a phono stage to match a tonearm? The Aura was designed to match a wide variety of cartridges and vinyl setups, and it does so extremely well.When I owned the Rega Aura, the quick access dials on the front for me were not a pretty sight and not necessary as once you have set the cartridge parameters for capacitance and gain you can forget about them unless you are going to change the cartridge very frequently (certainly not the design goal for Rega as the Aura was designed to be matched to the Rega RB2000 and RB3000 tonearms and Rega Apheta and Aphelion cartridges with their RP10, P10 and Naiad TT's ).
Also the fixed quantity of capacitance and gain settings are limiting if you want to fine tune your cartridge that is not a Rega cartridge.
I would say that only the 'Mono' and 'Mute' and possibly the 'Gain' press buttons would be useful to have on the front.
Just my 2 pennies worth from owning the Rega Aura !
The tonearm was mentioned in my post because the Aura was specifically designed and manufactured for the Rega Apheta and Aphelion Cartridges which were mainly designed and manufactured for the RB2000 and RB3000 tonearms. Not that the Aura was specifically designed for the Rega tonearms...lol ...that would be nonsense.The idea that the Aura was designed solely for the Rega cartridges and tonearms is complete nonsense. How do you even design a phono stage to match a tonearm? The Aura was designed to match a wide variety of cartridges and vinyl setups, and it does so extremely well.
Okay, you owned an Aura, and had to spend about 10 times as much to replace it. I'm sure the CH Precision phono stage is very good. At that price, I would certainly hope so, and I'm not suprised you have to justify your purchase by criticising the phono stage it replaced.
I'm not suggesting that the Rega Aura is the best phono stage on the planet - far from it. I'm sure that there are many that are better. But at or around its price - which is still very high by most normal standards - I personally have not heard anything better, and have heard some much more expensive phono stages that are far less musical, entertaining and engaging.
One of the things I require from a phonostage is that it must have the controls / loading on an easy to adjust dial on the front panel
It will be the biggest mistake in this hobby if you do that. If you think that a rip sounds as good as the record it’s sourced from you’re wrong.Through this process I'll slowly pare down my vinyl collection while still having all the music. Selling off the recorded LPs will fund my future systems' purchases without putting dents in my retirement dollars.
The Aura seems to be your favourite. But other prefer Superline / Supercap . these things are also system, ears dependant. And above all, it depends on the cartridge you have. If for example I had a top Dynavector cart with my Ear 912, I would say that my phono is a crap, with hum, noise, and low dynamics.The idea that the Aura was designed solely for the Rega cartridges and tonearms is complete nonsense. How do you even design a phono stage to match a tonearm? The Aura was designed to match a wide variety of cartridges and vinyl setups, and it does so extremely well.
Good luck if you do, you will always wonder if you dont! Remember import duty and the VAT-duty though.With everyone talking so much about the Lino C, I have been reading up on it. I am liking what I read.
I called Channel D to see if they have a UK distributor so I can borrow one to try out at home, unfortunately not.
After spending some time on the phone with Channel D, asking all sorts of questions about every aspect of the phonostage. When I finished I asked for the name of whom I was talking to, so when I email them I know whom to reference. I was surprised to find out I had been talking to Rob the designer himself all the time. I have to say the guy is very nice and helpful and answered all my questions.
I think I am about to do something, I never do which is to buy something blind without having listening to it in my system first. They have a 30-day money back guarantee, but since I am far away I cannot take advantage of this. If I pay the money, it’s a one-way trip so I better like it. Just making up my mind now whether to go for it or not.
I am looking at getting the one with the Current mode and the Voltage mode, that way if my cartridge does not work well with the Current mode at least I can use the Voltage mode. That is a $995 extra, but better safe than sorry.
