We'll have to agree to disagree on that one, micro. I think most recordings don't have any significant information down there to reproduce, no signal to amplify to move the driver and, therefore, nothing to create a "sense of spaciousness." And in the rare case that it does, I'll pass on that sense of spaciousness created by subsonic rumble. Not my cup of tea. YMMV.
Tim
Not quite true my friend. Few instruments have a range down to 20Hz but that is not to say a typical recording does not have a lot of information down to 20 Hz. I wish I could find those graph's of Bruce he posted two years ago of the average FR of non organ music songs. In my room I measure lots of 20Hz on ordinary music on my Phonic (my iPhone App measures down to only 30). So what makes up that content? Typically recorded or introduced reverb. Yup, it makes the soundscape appear larger which is why it was recorded or introduced in the first place. If scale matters that last octave matters.
We're fussing over the meaning of "significant" Jack. I've heard subs playing by themselves too many times to believe in the ambience contained therein. YMMV.
Tim
I'm certain that smooth, extended bass below the neighborhood of 50hz is one (small) part of the audio information that helps create the illusion of ambience. Ambience - natural and artificial reverb in a recording - is all over the frequency spectrum. I've sat in studios too many times and heard it turned on and off of speakers that went nowhere near 20hz. If you boys want to believe you can't get "ambience" without a few $2k subwoofers, enjoy that. But spend your efforts convincing your wives; you don't need my approval. And let's put this in perspective, in this conversation we're not debating mini-monitors vs full-rangers. We're talking about subs that go to 20 vs subs that go to 26. Let's do a blind AB/X to see if you can consistently hear that last 6 or 7 hz shall we?
Tim
Hi Tim, Speaking for myself, i have Wilson X1/Grand Slamms and run the Velodyne with a 38db rolloff at 38hz or so.
Not sure I followed this. You're crossing over to the Velodyne at 38hz?
Tim
So from 38hz to sub-sonic frequencies, you're running both the Wilsons and the Velodyne?
Tim
Tim
Tim
This is the Geddes approach run the mains full range and use the subs below the Schrodinger freq for the room to control
room modes.
room modes.
Tim,
If the the subs were playing by themselves, either they were faulty or badly setup - as people say, the best subs are those that are not heard, but felt.
Curious that your definition of accuracy authorizes you to exclude a part of the spectrum of the recording, mainly because it seems you do no like it or the studio monitors where the recording was mixed were not able to play it. You are becoming too subjective!
Tim,
Hmmm, that's interesting. I have not read up on this approach but my ears tell me that it works well with a musical sub. This is how I have my system set up when the subs are actually engaged, which admittedly is not too often as my mains do a fine job by themselves. That said, with some recordings the illusion is that the sound stage increases in size and realism with the subs running. IME, there is a significant amount of information at those frequencies. Not on all recordings but enough for me to not want to lose it when it is there.Really? cool...i did not know that, just found this worked best in the end. I have heard good things about Geddes.
