I would hope so but something tells me that you may need to purchase a special cleaner that runs a few hundred bucks for a small bottle!![]()
streak free at the molecular level. Doesn't glass resonate ? That material raises a red flag for me as far as speaker enclosures designed to eliminate resonance and driver back wave internal reflections.
I am no techie, but don't nearly all materials resonate at some frequency? Wood, Aluminum, perhaps even composites like resin wood or Rockport's poured mixture? In the case of this glass, is it tempered glass perhaps? With close to 4x the "strength" of regular glass due to treatment with extremely high heat and/or chemicals, i think tempered glass may be denser? Would this alter its resonance characteristics as well?
Cool! Good to know!! Thanks.I think Wilson and their x brace resin composite structure's resonance freq. is below what we can hear. I don't know if there are published stats on this or not. I we'll tell you that my family business is a global producer of various phenolic resins used in industry.Perhaps we are in Wilson's depending on who they source their resin compounds from. We only sell that stuff in metric tons, so Wilson wouldn't be buying stuff from us direct.
Hi Peter, seems to me that while the Cube does not use 'splash' in the same way that the Zephrin does, it does take advantage of the same human hearing rule by creating short delays in the room through the use of drivers firing to the side or rear. The ear/brain system uses the multiple delays to improve image location by making a copy of the first sound it hears (direct radiation) and then looking for additional similar sounds following it to create a better idea of where the sound came from. So a speaker employing this technique should have a wider, deeper, more palpable soundstage.
We use a speaker here at the shop made by a company called High Emotion Audio (the Bella Twin, last I look not on their website, but an easy 16 ohm load at 93 db 1 at 1 watt/1 meter), which employs a unique patented tweeter that has nearly as much output 90 degrees off-axis as it does straight on. It too has exceptional soundstage qualities as it is nearly omnidirectional above 2KHz.
Yes and IIRC Jonas told us the story in the Vegas video... they invented a resonance control substance that is part of the glass sandwich. When you give them the knuckle test they are dead and your knuckles hurt. I'm listening to them as I type and I remain very impressed. The sound simply blooms from the recorded event.
Sand is pretty dense, so melted sand into glass with some damping layer adhesive, ect may be well be well damped. Are these enclosures multi layer glass composite or one solid piece of glass per side of the cube ?
Peter,
How do these compare with the YG's you recently had in your room?
A box speaker that compares favorably with the MBL 101's. That's a feat.
GG
