Phasemation PP-2000
joeling
177
51
335
Just acquired one of these. Would like to seek advice from fellow members what is the besting loading for this cart. Thanks.
Reactions: CKKeung and hogen
Shuggie
103
129
113
UK
ammonite-audio.co.uk
For an active gain MC phono preamplifer, try 50 ohms or 100 ohms and choose whichever option you like best. Personally, I'd use a moving coil step up transformer such as Phasemation's own products, which are truly excellent and really liberate the performance of Phasemation cartridges.
Reactions: joeling
AMR / iFi audio
2,636
1,153
260
43
UK
ifi-audio.com
I've heard it and as I recall the best sound was about 100 Ohms, but I can't recall the exact value. It's a stunning cartridge, I enjoyed it very much. It depends a little bit on your cables too, so don't get stuck on one value and play around.
Reactions: joeling
joeling
177
51
335
Thanks for the insight. I am waiting for my arm base for Groovemaster III. Will mount the PP-2000 on this arm. @Shuggie, I am also exploring their Phono stages as well. I heard the PP-1000 on their EA2000 6 chassis phono. Very nice. However, 6 boxes is too many a box for me. No space on the rack o_O
Shuggie
103
129
113
UK
I've only heard the Phasemation EA-350, which I have here and is excellent, but even more so when used with the T-1000 dual mono SUTs, instead of the EA-350's internal SUTs. François at Ana Mighty Sound says the EA-1200 is pretty special, even if the EA-2000 is clearly better. I am in awe of the physical quality of all Phasemation products, which are truly high-end at mostly sensible prices.
Reactions: joeling
AMR / iFi audio
2,636
1,153
260
43
UK
ifi-audio.com
EA-350 is a great phono stage, but it doesn't use SUT. It has a separate input stage for MC which is a voltage amplifier, so you can think of it as a solid-state replacement for SUT. I could live with even EA-200 and PP-200, they make a killer combo for a reasonable price :)
shakti
1,444
2,412
480
Cologne, Germany
My personal winner is the combination of EA-1200 plus T-2000 step up.
You are close to EA-2000 performance with the bonus, that 3x MC carts can be connected.
Shuggie
103
129
113
UK
Sorry, but that is wrong. The EA-350 does have internal SUTs, clearly stated on their website https://phasemation.com/product/ea-350.html :
Last year, using our knowledge gained from making T-2000 which sparkled having won many awards last year, we built in a step-up transformer with a special split winding structure supporting balanced transmissions of a 26dB gain and this makes an MC balanced transmission.
shakti
1,444
2,412
480
Cologne, Germany
joeling
177
51
335
Very tempting indeed.
joeling
177
51
335
My problem is that I am too curious and I need more inputs :oops:
AMR / iFi audio
2,636
1,153
260
43
UK
ifi-audio.com
Maybe two phono stages with multiple inputs in each? That would be another point to mix it up. For example one solid-state and the other with tubes? With two cartridges that give you 4 possible sound signatures.
bonzo75
22,650
13,684
2,710
London
The phasemation 2000 was preferred to the CS port and Thrax phonos at Anamighty though they were very good too. Never got to try the 1200 with the phasemation SUT, I was interested in confirming exactly what you posted.
Anamighty had a very nice cable of their own that bettered the phasemation cable from the SUT to the phono.
It will be good to compare phasemation with properly rolled valves with Allnic 8000, EMT, Mayer, and a couple of the ones going direct from Eastern europe
Reactions: shakti
shakti
1,444
2,412
480
Cologne, Germany
My EA-2000 has now some more hours on and keeps to get better, so currently the EA-2000 is developing mainly in the area of the upper bass region, getting more energy and resolution there. EA-1200 is now a bigger step left behind in this regard (both with T-2000)
I am using the Phasemation 1000 cable series, not the cable which was supplied with the EA-2000, I have some more from the 1000 series, so the comparison can be done more fast.
EA-1200 likes little darker cables, EA-2000 likes little brighter cables, difficult to make a "fair" comparison with a final judge.
(at least in my set up, Solution 720 plus Heisenberg plus Avalon)
joeling
177
51
335
Gentlemen,
Thanks for all the insights. I will sleep on it for a while see how :D
Ed.P
71
95
123
Picked up one of these recently.
Solypsa
1,811
1,401
275
Seattle
www.solypsa.com
Love to hear your thoughts about the PP2000. Glanz arm right?
