Any first impressions? I'm curious about the Glanz tonearms. Don't leave us hangingYes, Glanz arm. The PP-2000 is still breaking in so need some more time to settle in. I only have 15-20 albums into it now.
Maybe you can try a lower downward force on the stylus? Usually, it helps. Try going -0,1 to -0,2g from the current setting. Sometimes even that helpsOk, I have finally mounted my PP2000 on at Groovemaster III arm. Sounds very nice. Can give the Koetsu stone bodies a run for their money.
However, I have an issue. When the needle is on the LP, there is a fair / high amount of what I can guess is groove noise that manifests itself like a hum. Lift the arm & its total silence. Needle in contact when LP not spinning, dead silence. Needle in contact with spinning LP, noise, humming noise.
Any owners with similar experience ? Is my cart defective ?
In comparison with my Koetsu or Benz Micro LPS on same phono amp, the PP2000 has a much higher level of hum / groove noise. Turn the volume down when the needle is in contact with the spinning LP, dead silent.
Help !
Mine exhibits none of these symptoms, very quiet in the grooveAny owners with similar experience ? Is my cart defective ?
Even in grooves w/o modulation? ( lead out etc. )Needle in contact with spinning LP, noise, humming noise.
Help !
Glanz is a very good arm. Mine only 10" & I have paired it with my DS Audio Grandmaster. On well recorded music, wow. Dynamics a plenty and so delicate & nuanced. Dare I say even slightly better than the FR66S + Blue Lace combo.Any first impressions? I'm curious about the Glanz tonearms. Don't leave us hanging
Sometimes we use words differently but to my way of thinking, if there is "hum" when the cart is dropped into groove sections with no modulation, but it disappears when the cart is lifted off the record then I would surmise something is wrong / broken. I am only a little confused because if the suspension being loaded causes a hum to appear I would think it would happen if lp was spinning or not with unmodulated groove segments.5) lead in / lead out - hum as long as needle on the LP
I hear an undulating hum / noise with a steady rhythm whether music playing or in between songs. Seems like I am hearing the platter spin but that seems weird as the platter should b floating on air.Sometimes we use words differently but to my way of thinking, if there is "hum" when the cart is dropped into groove sections with no modulation, but it disappears when the cart is lifted off the record then I would surmise something is wrong / broken. I am only a little confused because if the suspension being loaded causes a hum to appear I would think it would happen if lp was spinning or not with unmodulated groove segments.
If we are talking about "excess groove noise, clicks pops etc" as the cart tracks along then its still not good but the problem may stem from different issues.
1) With other carts no hum at all.Maybe a long shot.....
If you try with different cartridges on the same tonearm and turntable and still have hum issues (albeit at different sound levels) this could be a ground loop issue;
1) Have you checked the grounding connection of the tonearm to the Phono Stage (assuming your tonearm has a separate earth ground cable to connect to the ground connection of your phono stage) ?
2) Are the tonearm wiring end connections ok i.e. properly wired from cartridge pins to the tonearm cable end connections etc. ?
I had a similar problem with pronounced hum with my Rega Reference P10 Turntable with Rega's Reference RB3000 Tonearm and Rega Apheta 3 cartridge linked to the Rega's Reference Aura Phono Stage.Anyway, some discovery. Mounted a Koetsu & lo & behold, hum. Tonearm arm tube was over the top of the SF3P motor. Changed the location of the tone arm. No more hum for the Koetsu. Hum on the PP2000 is reduced but not gone. I guess the Phasemation is more sensitive.
As noted by other members before, this sounds like a ground loop issue. Remove AF3P grounding cable if it’s attached to phono stage. You can try removing tonearms ground cables and only attaching turntable’s ground to the phono stage. Since AF3P’s base and arm boards are all metal they make electrical contact with tonearm base which is connected to tonearm ground. I have experienced this issue with AF3P and SAT CF01 before.Anyway, some discovery. Mounted a Koetsu & lo & behold, hum. Tonearm arm tube was over the top of the SF3P motor. Changed the location of the tone arm. No more hum for the Koetsu. Hum on the PP2000 is reduced but not gone. I guess the Phasemation is more sensitive.
It sounds as if your problem has been solved- EMI interference from the motor? Or I'm reading this wrong?Anyway, some discovery. Mounted a Koetsu & lo & behold, hum. Tonearm arm tube was over the top of the SF3P motor. Changed the location of the tone arm. No more hum for the Koetsu. Hum on the PP2000 is reduced but not gone. I guess the Phasemation is more sensitive.
As mentioned by @Bonesy Jonesy it's most likely to be hum from the motor. Some cartridges are more susceptible, and some are less. Shielding that is quite complicated because it is most likely either magnetic or electric coupling.Anyway, some discovery. Mounted a Koetsu & lo & behold, hum. Tonearm arm tube was over the top of the SF3P motor. Changed the location of the tone arm. No more hum for the Koetsu. Hum on the PP2000 is reduced but not gone. I guess the Phasemation is more sensitive.
Maybe the platter is not grounded correctly? I'm afraid you need to see a technician or wait for them to fix it.For the moment, my task is to mount the PP2000 in another table to try. However, I do not think the issue lies with the PP2000.
More disturbing is the faint noise from the motor and vibration from the power / pump unit that was not there previously.
With my hand touching the arm tubes, I could sense some faint vibration from the Groovemaster but not the Glanz or the FR.
Through the course my trouble shooting, I realised perhaps the table needs some attention. When it was delivered, the holding / transport bolts on the pump unit were dislodged and left gashing holes on the bottom of the unit. I reported to my dealer but fired up the unit anyway. Did not seem to be an issue until now. Anyway, my dealer did mention that factory will replace the unit with a brand new one but that was in February. Time to chase.
As an aside, the Groovemaster + Tiger eye combo is very nice indeed.
Ground cable of table connected to phono stage resulted in fairly loud hum
Ground cable of tone arm not connected to phono stage resulted in hum
