Phono Stage and XLRs
jadis
12,829
5,931
2,810
Manila, Philippines
I have been wondering how XLRs in a phono cable and into a phono stage with XLR input works. (XLR plug to a Din end connector). My simple mind tells me the phono cartridge has 2 pins for tonearm wires per channel. The XLR plug has 3 pins/wires. Where is the 3rd pin/wire connected to the cartridge which has only 2 pins per channel? I understand XRL cables are 3 pins to 3 pins from input to output and vice versa.
Reactions: Jim Hagerman
All cartridges are balanced. Therefore, one should use a balanced phono stage to benefit from the extra 60dB of common node noise rejection.
The positive output of the cartridge goes to pin 2 of the XLR, the negative output to pin 3. Pin 1 is ground, which can be used to ground the shield of the cable if there is one, as well as the ground of the tonearm, even though there is usually a separate ground lead from the tonearm.
Thanks for the info, Adrian.
Cartridges are not balanced, they are floating. A balanced connection requires 3 wires, not 2, hence XLR connectors.
In order to be balanced, both output polarities (+ and -) need to have the same impedance to common mode ground (this happens in phonostage). Connecting pins 1 and 3 together destroys common mode noise rejection. Pin 1 does act as a nice shield if only connected on the RX end, but you still do not have balanced drive. If impedances are not matched and you do not get CM rejection.
There are two ways to make a balanced phono connection:
1) Use a pair of 23.5k resistors to ground for each cartridge terminal. Thus, you get balanced drive and a 47k differential loading.
2) Use a step-up transformer with center tap on input. Connect center tap to ground. Bingo!
jh
jh
Thanks for your explanation, Jim.
Resistors are not needed, the input resistances of the balanced amplifier perform their role. And they also divide the signal by 2 times, and also worsen the signal-to-noise ratio by 6 dB.
Reactions: jadis
Well yes, the 47k loading is provided by the balanced amplifier input. It does not however, cut signal amplitude in half. Cartridge sees only the 47k. If balanced with 23.5k each leg to ground, you have both + and - polarities, which are -6dB with respect to ground, but the circuit amplifies both of them. No loss of signal, no change in SNR.
Reactions: jadis
It doesn't matter if it's 47k or 23.5k. Two resistors are a signal divider from the cartridge. From 5mV, for example, they make 2.5mV on each of the balanced inputs, 2x2.5=5. That is, the signal is 6 dB lower, and the noise level is the same.
Here each method is examined from a technical and measurement point of view. unbalanced, balanced, differential signals. all advantages and disadvantages.
Figure 14 - Transformer Output Driving Unbalanced Input is probably interesting for many people here
No no no. When doing it like this there is no signal loss. Noise level is same (ignoring any improvements via removal of hum).
Yes Yes Yes. What do you call losses? In the case of balance, 2 times smaller signal enters each amplifier. The output signal is the same, but it has noise from 2 input amplifiers, not from one as in unbalanced mode. From 6 dB of deterioration there is nowhere to go.
  • Sad
I don’t agree. Since the cartridge is already balanced, there is no need for XLR cables. You are introducing additional transformers into the signal chain if you use XLR, which is why most high end phono stages don’t have an XLR input (eg, Nagra, DarTZeel).
Reactions: mtemur and jadis
There are always advantages to using XLR cabling, no matter how the signal is further processed in the phonoamp. Because with RCA cabling the shielding is also signal ground at the same time, interference from outside is brought into the highly amplified stage of the phono amp. With XLR balanced the shield from the cable is only earth if done correctly no contact to signal ground.
On the subject of input transformers, it is always good to add an amplifying element that does not add any active noise*. You can choose a lower gain in the phono preamplifier, which reduces noise again. Whether you like the sound of it is another matter. mostly depends on taste and the quality of the transformer. From a technical point of view it makes sense.
*low measurable current noise
No, only for long runs are balanced connections beneficial.
Higher transformer inductance from a balanced connection will deteriorate the sound quality. This is why Nagra, and others, do not even include the option of an XLR input. These are cost no object designs, if there was a sonic benefit- the option would have been included.
Reactions: mtemur
That is not correct.
CH Precision, the so called best phono ever, the 80K P10 phono have XLR inputs.
As do EMT, Burmester , D'Agostino, Phasemation, Vitus, Accuphase, Aesthetix, Esoteric to name a few.
The XLR inputs are there for convenience, not for sound quality.
Reactions: XV-1
LOL. since when is XLR inputs for a phono stage a convenience. The overwhelming phono cables that people use are RCA.
I stated why above.
Exactly my point!
I would seriously doubt the competency of any tonearm manufacturer who provides XLR outputs from the arm.
Reactions: XV-1
