Playback Designs DAC vs. Scarlatti DAC
Keith_W
1,024
95
970
Melbourne, Australia
www.whatsbestforum.com
Congratulations on your purchase and welcome to WBF! Out of curiosity, what is the difference between the MPD-3 and the MPD-5? I know that the difference between the MPS-3 and MPS-5 is that the '3 can not play SACD, but I understand that the MPD-3 can handle DSD. Why would anyone bother with an MPD-5 then?
LL21
14,430
2,518
1,448
Hi Keith, I went to the site and believe the MPS-5 can also handle DSD...so in fact, it basially does SACD over the MPS3.
Mike Lavigne
Apr 25, 2010
12,602
11,695
4,410
the MPD-5 has a more involved chassis, and all circuit boards are separate with a higher parts count, than the MPD-3. i own the MPS-5 myself.
if you heard the MPD-3 and MPD-5 on separate days you'd be hard pressed to recall any difference. head to head the MPD-5 is more refined sounding.
bitstream
9
10
910
San Francisco Bay Area
MPD-3 has fewer inputs, and specifically has no optical input. Fewer parts? Perhaps. Still a substantial piece of equipment at 27 lbs. shipping, 22 lbs. out of box. And that's the DAC only (no CD transport).
treitz3
Super Moderator
Staff member
Dec 25, 2011
5,480
1,010
1,320
Hello, bitstream and welcome to the forum! Congratulations on the Playback Designs MPD-3 purchase. I'm glad to hear you are enjoying the end result.
Tom
Keith_W
1,024
95
970
That's good to hear. I own an MPS-5 myself also. I have been thinking of going for multichannel SACD, but that would involve buying an external MPD-5 and ganging up my MPS-5 to it. If the MPD-3 is close enough, it should be suitable for a multi-channel setup, you think? To get 5.1 you would need an extra four channels of DAC - very expensive if you have to buy two MPD-5's!!
Have you heard a multi-channel setup with the MPS-5 as the SACD player?
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
www.pugetsoundstudios.com
I use my MPS-5 all the time with surround discs/files. The DAC I use is the EMM Labs DAC8-IV. It's the best surround I've ever heard.
Mike Lavigne
Apr 25, 2010
12,602
11,695
4,410
when i had my multi-channel set-up for music in my 2-channel room i had the EMM Labs gear with the EMM Labs multi-channel preamp. that was before i got the MPS-5.
