Oxeon noticed the success of Rockport's drivers and started a company called SB Acoustics.SB Acoustics drivers are still not the same as Rockport's. Rockport uses rohacell as a core and makes a sandwich construction driver which is superior to SB Acoustics technique of layering carbon fiber on itself because it has a superior stiffness/weight ratio
SB Acoustics have different story and not connected to Oxeon.
sbacoustics.com
Texreme diaphragms supplied to many speaker manufacturers. SB use it in Satori series
Rohacell is another story. SB use it in CRC series - mid-class of drivers, they sound close to Satori, but not that fine, as Satori have different and more advanced construction.
As it is ipossible to compare face-to-face custom drivers from Orion to stadart SB Satori, there is no answer which one sounds is better, but my experience say that Satori will be same or better. To make objective comparison is not easy, as the driver is a part of speaker and while it have some parameters what may be worse then standart driver but others may be better as it designed to fit specific cabinet voulume, shape, crossover and will match to overall design better then standart what may have more advanced tech and parameters.
Yes, some people may be misleaded if they see textreme structure and may think that that it is SB Acoustics, but the driver may be produced by many other manufacturers.
Textreme is quite good for diaphragms - ligtht as paper and stiff as hard domes/cones, and got a hype and some manufacturers use it's visuality to attract customers. You may find it in Borsessen speakers - the drivers are some alu sandwich, but painted to look like textreme.
Having Textreme diaphragm does not mean that one driver sound better then others from different manufacturers, as a lot depends on final design and tech.
Sometimes manufacturers may claim that they develop something very special and no one can offer that product and no one can compare it to alternatives. Means that manufacturer gains that he is the only one who do it and that it have very unique feature what allows to claim that his final product better then others. That is very good for marketing and increased price.
Mods: would it be better if you create a new topic and move part of thread about drivers/construction there?
