Thank you for your comments. They have served me fairly well in my system, making things sound a little more balanced and less like smiley-face-EQ. I hear no tonal balance differences between the ZenWave D4s and my Elations (although that may be due to having Elation speaker cables).
Francisco, can you briefly explain the effect of capacitance on cabling? Why is high capacitance problematic?
Ian - sorry I missed this. I find KS to have a midrange forward quality (all of them that I have tried in my system, and pretty sure an Elation PC was in the mix once as well - and yes, Alex loves that quality as we've heard in my room several times where I disagree with him - isn't that why audio is great?) which may work well in some systems, but your comments about the CJ GAT having a very forward presentation doesn't exactly seem like the right pairing.
But yes, Alex is correct that I'm not a big cable fan in general. Bazelio on this forum is a good reference on cables and has done many swaps over the past year - we share similar thoughts on KS.
Yeah, I'm with the crowd who says KS is not neutral and Keith makes a good point. I would agree.
And as I mentioned, with D4 having a more forward presentation coupled with slightly tizzy highs compared to most other cables I've auditioned, I wouldn't recommend it for systems where fatigue is the complaint. Something more even-handed and laid back will go a long way in that case. If you audition the Masterbuilt (even the Reference line), I think you'll see what I mean. The Reference line has some sonic drawbacks, but you should experience a noticeable fatigue reduction vs D4. The Dart stuff is fantastic, and you should give it a chance to shine IMO.
How would you describe the differences (e.g. tonal balance) between KS Elation and the D4s - besides what you're hearing as tizzy highs on the D4s?
I haven't done a direct compare of those two in the same system at the same time. But my notes on the KS are along the lines of having a mid-range push, but with better frequency extension than other KS I've heard, and lacking the resolution of some of cables that I prefer. That said, I'd expect to hear notable differences between the KS and D4 side by side, in my system. If you don't, that might be a function of system transparency.
Wow.
First you speculate after not having heard the cables side by side, and then based on those speculations you take a speculative dig at Ian's system, which is very transparent and sensitive to cable changes. Great job, Bazelio.
Slow down, Al. We get it, you own a D4 cable and don't want to read a potentially negative comment. Is Bazelio's opinion any less valid in his system which you haven't heard? His Marten speakers aren't exactly known to be colored either. He's just reporting his experience, nothing wrong with that.
BTW, can you tell us what means exactly "very sensitive to cables" in your sentence?
I said "sensitive to cable changes". Another way of saying the system is transparent.
Back to the OP, what is the general opinion on 'A Good Pre-amp is No Pre-amp' statement. There was a flurry of interest around using a passive a few years ago. And for those with a one sure system, some may argue you can go direct to your power amp if the DAC has an attenuator.
The common argument against a passive inline between the DAC and Power amp has been the impedance shift. But I found a convincing article that stated an inline attenuator is not an impedance in, impedance out device, rather an inline resistance only.
Thoughts?
http://www.rothwellaudioproducts.co.uk/html/the_truth_about_passive_pre-am.html
Not all passives are alike. I'm using an AVC (autoformer) based passive line stage - similar to TVC although simpler. I'm definitely a "no preamp" is the best preamp guy at this point, and won't be going back to actives. Intuitively, there is no way in my mind that an extra power supply and active devices in the signal path can ever improve the sound (save for system impedance mismatch resolution, but see below). It can color and veil the sound which can be a matter of taste, but it can not objectively improve it. Now, in my estimation, my AVC is roughly 90-95% of "no preamp" in sound quality. And it is humorously better than any active line stage I've heard. I was able to test "no preamp" vs the AVC when I had an amp with rear-mounted per-channel volume control.
Now, impedance matching may not be an issue with an AVC passive in many systems. The load is reduced 50% for every 3dB you attenuate. I have enough gain in my system - as do 99% of systems - that even with the passive line stage, I'm at about 55% attenuated (say 11:00) for a loud listening volume. 11:00 is about -28dB, so the load is reduced by over 100x which means the source really sees only the inductive reactance of the autoformer since the 220 kOhm input impedance of my Dartzeel amp becomes trivially light at that point. My autoformer is a Slagle, and Dave says it is gapped at about 100H, which is about 12 kOhm all the way down at 20Hz and rises from there. Stereophile measured my EAR phono OI to be 60 Ohm. So 12000:60 = 200:1. Not bad at all. The result: transparency, inner detail, and articulation that are second to none.
Interesting. I had assumed you had darTZeel for some reason.
Do you have complete measurements of your Dave Slagle autotransformer? I own and have measured distortion at several frequencies and levels of a few line audio transformers from Jensen, Lundhal, Sony high-end and all of them had a clear sonic signature showing in the measurements. Curiously the worst measuring one just looking at one figure measurement - an unknown brand used in the FlexConnect was by far subjectively the best sounding!
Can I ask why do you consider that the considerable distortion and noise of your DartZeel power amplifier improves sound quality and that of the preamplfiers does not improve sound quality?
