NorthStar bear in mind for damping factor (whole context amp-to-speaker) you have both electrical and mechanical; so some of this also depends upon the design-implementation of the speaker.
Cheers
Orb
So, what game ARE you playing?
An amplifier with wide band (frequency range) and linear (no deviation), say from 1Hz to 300kHz (+/- 0.5dB); should sound better than one with a measured frequency response of say from 10Hz to 100kHz (+/- 3dB).
Ethan, what is your take on Slew Rate?
...And Damping Factor, why not.
I can't imagine why an amplifier (or any audio device) whose response extends beyond the audible range should sound any different from an amplifier that's limited to the audible range.
I can't imagine why an amplifier (or any audio device) whose response extends beyond the audible range should sound any different from an amplifier that's limited to the audible range. Your comparison above isn't meaningful because one limit is +/- 0.5 dB and the other is +/- 3 dB. As long as both are flat within half a dB or so in the audible range, that should be flat enough to not matter. What happens beyond that range shouldn't affect the sound. If you play a CD for the source, its own response is hard-limited at around 20 KHz, so an amplifier that can pass frequencies higher than that won't have anything to pass! And good luck finding a speaker than can reproduce 100 KHz!
I recently wrote this short article about slew rate to complement my Audio Expert book:
Slew Rate And Slew Rate Limiting
As for damping factor, it's important, but it's not an issue with modern solid state power amps. In practice, damping factor is limited to around 50 simply because the speaker driver's own voice coil is in series with everything else. I'm addressing both of these issues in more detail in my workshop Lies, Damn Lies, and Audio Gear Specs at the AES show in a few weeks.
--Ethan
Dont forget the speakers most have significant roll after +- 20 khz anyway
What comes in doesnt come out
I would bet that you are right.In my opinion 25 khz is more than enough
No designer of an extended bandwidth amplifier will tell you that his amplifier sounds better because it is able to reproduce 100 kHz. Usually the extended bandwidth is a consequence of another objective of the design - the designers of Spectral, Burmester and Soulution, just to nominate a few known examples, have explained in the past the whys of their options.
two sources can mix acoustically producing sum and difference frequency components where the difference components can be heard.
if a high res file or SACD, with supersonic content is played into an amp that can reproduce that content that, while we are not capable of hearing the supersonic content itself, it can create IM within the audible range?
Sum and difference IM frequencies are generated only in the presence of nonlinearity. Simply combining two frequencies, whether electrically or acoustically, does not generate IM products.
Since the early 1960s, researchers have been experimenting with creating directive low-frequency sound from nonlinear interaction of an aimed beam of ultrasound waves produced by a parametric array using heterodyning. ...
...A transducer can be made to project a narrow beam of modulated ultrasound that is powerful enough, at 100 to 110 dBSPL, to substantially change the speed of sound in the air that it passes through. The air within the beam behaves nonlinearly and extracts the modulation signal from the ultrasound, resulting in sound that can be heard...
http://www.acoustics.org/press/133rd/2pea.htmlNon-Linearity of Air
When two sound sources are positioned relatively closely together and are of a sufficiently high intensity, two new tones appear: a tone lower than either of the two original ones and a tone which is higher than the original two.
There are now four tones where before there were only two. It can be demonstrated mathematically that the two new tones correspond to the sum and the difference of the two original ones, which we refer to as combination tones.
For example, if you were to emit 200,000 Hz and 201,000 Hz into the air, with sufficient energy to produce a sum and difference tone, you would produce the sum - 401,000 Hz - and the difference - 1,000 Hz, which is in the range of human hearing.
The HSS concept originates from this theory of combination tones, a phenomenon known in music for the past 200 years as "Tartini tones." It was long believed that Tartini Tones were a form of beats because their frequency equals the calculated beat frequency. However, it was Hermann von Helmholtz (1821-1894) who completely re-ordered the thinking on these tones. By reporting that he could also hear summation tones (whose frequency was the sum rather than the difference of the two fundamental tones) Helmholtz demonstrated that the phenomenon had to result from a non-linearity.
Well there's a product called the Acoustic Spotlight that relies on nonlinearity of air:
Actually my rights stop at the tip of the other guys nose. not mine.
