Hello, I wonder what folks thoughts are on this topic.
Is it possible for an aluminum cabinet to attract EMI/RFI/EMF noise compared to say a wood or other non conductive enclosure material? If so, is there such a thing as someone "grounding" a speaker cabinet to earth to eliminate such things or would that not do anything at all for such an issue?
I've recently aquired new S3 towers and immediatly after their installation I noticed some HF interference from the tweeter/mid driver that I've never encountered before in my room with the same equipment and my previous wooden speakers.
I've narrowed down that the issue is not related to the Input signal as I can remove the XLR connectors from the amps and still hear the same noise. I've also eliminated the speaker cables and power cords as being possible culprits as well by switching those out for different ones with no change either.
Lastly, I believe I've eliminated the amp as being a culprit by swapping in a different set of amps and the noise still occurred. But, I should also mention that even though I've swapped amps both amps are of the same type/flavor (Class D Hypex) but both are known for their very low noise floor and neither pair of amps made this noise hooked up to previous speakers (B&W 803D2).
I've captured a sound clip of the noise which comes from both speakers mainly during the first 10mins of initial power up of the amps afterwhich it dies down significantly. After 10mins or so the only remaining noise I hear is a very high pitched (16khz or so) constant whistle when my ear is right up on the tweeters. During the first 10mins the noise I hear is loud enough to hear across the room and that sound is in the 8khz range of the audio spectrum (according to an APP used on my I-Phone).
The things I find strange here are that the noise comes from both speakers which are powered by a set of mono blocks so it's very unlikely to be related to any one amp having some kind of issue.
Here's the kicker and the main reason for my question in this post. Today while probing around the listening area with my trusty AC/Current "No Touch" sensor to look for possible sources of the noise I looked up and noticed my ceiling fan staring at me. The fan is probably 3-4ft away from the top of the right speakers cabinet. As I raised the voltage sensor up towards the ceiling fan it started going wild with alerts. Now bare in mind that my hand was still at least two feet away from the fan itself when the device started alerting me of voltage being present. I should also mention that the light and fan were NOT turned on.
One last point to mention here and that is my house is very old (120yrs) and still has some old school knob and tube wiring in place. I suspect that this ceiling fan may not be grounded and is probably wired up using the old wiring.
If there is any interest I can post up the sound clip I captured of the noise I hear but I'm curious to hear people's thoughts on this. Could my beautiful aluminum speaker cabinets be picking up some voltage spray from this fan or other source I've yet to identify due to their build material?
Thanks for your thoughts on this topic
