Ps audio P10/5
Alrainbow
3,279
1,442
450
I have a new office rig and I am doing everything from top to bottom correct. .
I cam across the ps audio power regenerators. The really do make a big difference in the sound as well as video. They just released a new firmware for multi wave. It has increased detail every where .
I highly reccomend the product even for a trial it does work .
Al
Hi Al, interesting how mains treatments now has several different directions to go in - mains regeneration like your PS Audio, and Isotek Evo3 Genesis/Titan; balanced power like my Westwick 8kVA, and EquiTech; grounding solutions like my Entreq Silver Tellus and Tripoint Troy; noise filtering like Shunyata; and good old fashioned conditioners like Audience etc.
Obv, all bring a lot to the table, glad PS works for you. I felt their transformer didn't quite have enough headroom for my needs, so settled on combination of Westwick 8kVA balanced power, and grounding each component via Entreq.
I guess the core was not large enough . I thought for sure it would have a negative effect on the power amps , but it did not at all. It truly improved all. The most obvious was the tv when I turned it on, I thought it was the channel maybe broadcasting in 1080P. Then I remembered that tv only does 1080I. There are many paths and you are correct, and I have no tried many. So I am sure there are many paths to try. My office is set up for the rig with proper gnd and seperate circuits same phase . And oversized wiring all with common gnd to,panel and isolated devices. But this is not cheap to do either
The ps audio comes with a hefty price . But it does many devices at once .
Al
Hi spirit of music,
I am looking for a power filtration system and selected the Silvercore netzfilter ... but have not decided yet if I would not rather go for a balanced power conditioning. I am looking at both equitech and westwick, as I live in a london rental house, it means I can not do wall mounted cabinet and dedicated power line. What made you choose the Westwick 8Kva ?
