Record Cleaning Machines
Johnny Vinyl
May 16, 2010
8,571
11
38
Calgary, AB
Hello, John. Those are good suggestions. How is the humidity level in your listening room? IIRC, you have a carpet that you most likely walk across that may be introducing unwanted electrical charges as well. Adjusting the humidity level may thwart some of the static buildup.
Tom
Good morning Tom. The humidity level seems fine as I'm not getting any charges when touching my system or anything else I do around the apartment. I'm quite convinced it's the RCM's doing.
garylkoh
Sep 6, 2010
5,459
39
265
Seattle, WA
www.genesisloudspeakers.com
In Singapore, where relative humidity is often above 95%, any residual fluid won't evaporate and so I run 5 - 6 revs under vacuum. In Summer in Seattle, where relative humidity is much, much lower, I have gone as far down as 1 rev under vacuum. If you do a distilled/RO water rinse, then if the grooves are still a little wet, it won't hurt. And if the grooves are a little wet, it will reduce static further.
MylesBAstor
7
315
New York City
But that residual (just as moisture from blowing on the record) water will crud up the stylus as shown by Peter Ledermann. :(
garylkoh
Sep 6, 2010
5,459
39
265
Seattle, WA
That's why I mentioned a distilled/RO water rinse. If you have reagent-grade water, it'll be even better.
allvinyl
263
43
110
69
Burnsville, MN
RCM + Ultrasonic Methodology
All - I recently discovered the following regimen which is giving me pause to think I need to re-clean my entire collection... uggghhhh!
Hardware: VPI 17F, Last applicator brush, UltrasonicRecords V8 with water heated to 25 to 30 C, Audio Intelligent Enzyme fluid, Distilled water, 3, 4 drops PhotoFlo(the UR V8 takes 2 gal distilled water in which I put 3 drops PF), rubber coated dish rack.
1. Using a clean Last applicator(those white or gold thin plastic handled brushes) I apply AI Enzyme fluid. The painful part is holding the brush lightly on the LP as is spins for a total of between 2 to 3 minutes of continuous fluid agitation reversing the direction of the 17F turntable every 20 - 30 seconds. You develop a "feel" for when the fluid has done its thing.
2. Vacuum off the fluid(I've been using 5 revolutions to assure as dry a record as is possible with the 17F. Amazingly, I have not been able to generate any static. Kinda wierds me out.)
3. Place LP on the UR spindle.
4. Repeat steps 1, 2 seven more times til I have 8 LPs on the UR spindle.
5. Run the usual 10 minute cycle through the V8.
6. Place LPs in dish rack to air dry.
I tried the AI (Listener Select) brush for applying/agitating the fluid but it pales in results to the Last applicator. It's amazing how you can feel the fluid do the work. You just have to stand there and hold the brush on the LP as it spins, reversing occasionally.
I am completely aghast, in a good way, how transparent, click/pop/tick/STATIC free, open, (you name a superlative) LPs are after this process. Next step is to replace the distilled with reagent water in the V8.
John
topoxforddoc
Active Member
Feb 20, 2015
63
2
38
Cheltenham, UK
I use an old Keith Monks RCM. It's an early machine (probably 35-40 years old) and still going strong. Built like a proverbial tank - works really well. What's not to like? This one should see me out. I'm not sure that you could say that about all of the newer ultrasonic machines - how many of these will still be working in 10 years, let alone 40?
Likes: Gregadd
Stump
126
43
110
Nitty Gritty have been around a while.I dont used since I have a KLAudio which are now no longer made..
kach22i
Apr 21, 2010
1,447
151
225
Ann Arbor, Michigan
www.kachadoorian.com
Been reading that cleaning adds static.
What is the best way to remove static for good?
Now I read this:
https://www.sleevecityusa.com/GEM-Dandy-Hydraulic-Record-Cleaning-Apparatus-p/gem-dandy.htm
Vacuum machines can damage your record, both by flattening the lands, the delicate raised areas that separate the grooves, with the force of suction and by drying cleaning fluid prematurely with the blast of air being sucked into the machine, sometimes even picking up dust from the surroundings and dragging it across the surface of your record.]
tima
1,568
1,080
230
the Upper Midwest
Now I read this:
There is little unique about cleaning a record that causes static beyond any other object rubbed in contact with something (like a brush.) Electrons move, electrical charge builds up.
I don't know of a way to remove static permanently from records. Even pulling a record from its plastic sleeve can cause static build up, although there are sleeves that claim to be antistatic. Try increasing the humidity in your home. Short term, the Zerostat gun can remove static, sorta. Furutech makes two different anti-static brushs that work. There is an interesting electrical device from DS Audio called the DS-Ionizer; it was discussed in a thread here on WBF and costs north of $1500..
--> Do not put stuff on your records like Gruv Glide or anti-static sprays.
The quote you offered sounds like it was written by someone trying to sell you a product by saying something negative about alternative products. Imo, I'd pay no attention to either it or that product.
Vacuuming a record can be a source of static. Vacuum machines vacuum, they do not clean - the cleaning is left to you. The better vacuum machines are from Monks and Loricraft; they don't use brushes placed around a suction slot (eg VPI) but rather a nozzle that rides across the record like a tonearm. Ultrasonic machines clean but don't vacuum. The biggest challenge for ultrasonic is drying the record. See my article here for a discussion.
There are other threads in this sub-forum that discuss various off-the-rack machines and DIY alternatives for cleaning records.
kach22i
Apr 21, 2010
1,447
151
225
Ann Arbor, Michigan
Thanks for the reply tima.
Took me almost two hours yesterday to clean up my old Record Doctor, and getting the 20 year old adhesive strips off was not fun.
However, I am now cleaning records, with hearing protection on. Cueing up a record with ear protection on because I forgot to take them off was a bit funny.
tima
1,568
1,080
230
the Upper Midwest
Congrats - cleaning records is a good thing!
I had a Record Doctor years back. It was my first machine. It does need new lips from time to time - keep those lips clean and rinse records well with distilled water. Iirc it was loud; I guess that's why you're using ear plugs. The fluid sucked off goes into a sponge inside the box where its supposed to evaporate. Eventually the bottom of the particle board box kinda rotted on mine. But its a start.
I think the latest Clearaudio machine is around $6k.
How many records to you have to clean?
kach22i
Apr 21, 2010
1,447
151
225
Ann Arbor, Michigan
I have a 6' x 6' Ikea Kallax 75 percent full of records.
On a few records there are familiar non-removable pops/ticks using the Nitty Gritty nylon brush.
I have good luck getting such things out with a drapery steamer but it is a harrowing thing to put an LP through for just one or two slight imperfections.
I'm considering better fluid and a better brush for starters.
One recent comment stated the record cleaning machine only sucks the fluid off, that the user cleans the record with the brush.
So which brush?
Lots of talk about fluids and enzymes in this thread, very little about brushes unless they are part of a fully auto machine.
kach22i
Apr 21, 2010
1,447
151
225
Ann Arbor, Michigan
Thanks, that is the brand I was looking at. Was not sure about the brush.
Looks like No. 6 will fit my life style as I can use a drapery steamer for the really narly stuff.
Quote:
Designed with agitation in mind, Osage Audio, another of Jim's brands, offers Listener Select brushes sized for 12", 10" or 7" records ($29 each).
I could not decide between the MoFi brush and the Osage.
Leaning towards the Osage as I also have a Nitty Gritty in an unopened package.
tima
1,568
1,080
230
the Upper Midwest
You're welcome. When I wrote that, I got to try the Listener Select brushes which I came to prefer over the Mobile Fidelity (originally Record Research Labs.) The Mofi brushes are well made but they're flat and designed for spreading fluid which tends to lead to pressing into the record and rubbing. I believe that scrubbing is the wrong approach. The technique is described in the section titled "Progress is born of agitation", let the fluid do the work. Make sure to rinse well.
Likes: kach22i
Folsom
4,784
749
220
Eastern WA
These are on sale right now. Just ordered one to replace my ghetto home made version I was to embarrassed to post on here. That along with this for vacuum cleaning is a good place to be. I'm going to use distilled water, hepastat, and surfactant (Triton X) with a tiny bit of ethyl alcohol in the ultrasonic. Then for the rinse and vacuum will be a touch of hepastat and plain distilled water.
I was to kind to say something at another time, but a vacuum does not cause any static. It certainly doesn't cause anymore than fans mounted in some utlrasonic cleaners. Air is air, there's no if ands or butts about it. The reason people are use to vacuum systems causing static is because alcohol itself causes static on LP's. Pure water and hepastat actually neutralize static.
  • What’s Best Forum is THE forum for high-end audio, product reviews, advice and sharing experiences on the best of everything else. A place where audiophiles and audio companies discuss existing and new audio products, music servers, music streamers and computer audio, digital to audio converters, turntables, phono stages, cartridges, reel to reel, speakers, headphones, tube amplifiers and solid state amplification. Founded in 2010 What's Best Forum invites intelligent and courteous people of all interests and backgrounds to describe and discuss the best of everything. From beginners to life-long hobbyists to industry professionals we enjoy learning about new things and meeting new people and participating in spirited debates.
