The wall in back of my loudspeakers is made of flabby Gypsum plaster (sheetrock in the US) and it starts to resonate somewhere around 40-50hz.
I am looking for a suitable replacement and I came upon aerated concrete as a possible solution. It comes in blocks made ??of sand, lime and cement. When aluminum powder is added during the production process, these materials react with water to create a porous structure. It is lightweight and the blocks can be cut with an ordinary hand saw, fitted, joined and covered with any number of finishing materials.
Does anyone know if this would work to eliminate my problem? The room is narrow, long and entirely open under 1/2 of a roof. It was once a loft. I listen on the narrow axis (about 3m wide). This can not be changed as it is lies in the middle, in between a living and dining space. The wall at my back is made of brick. I like everything about the sound because it can be heard throughout the entire space and I don't actually spend much time seated in front of my speakers when music is playing, but when i do, the only thing that vexes me is the flabby wall in back of my high efficiency speakers, which have adjustable baffles (with different opening sizes) in the back and which don't go much below 40Hz, enough to hear the resonance. It is disturbing. It is not a problem with my LS3/5As.
