Wonderful- look forward to it.I have little doubt there are other amps that will work. Maybe some even better. IMO the Diablo was key.
A detailed description will follow.
No, thank you. It is a refreshing change of pace to have someone adamantly request a recommendation. A more common experience is a request for silence because I am ignorant. Smile.Thanks for sharing! I want to know if you have any recommendations for wireless headphones?Like Jlba, JBL, Naenka.
Amazing insights and listening notes! Thanks for taking the time...very interested and actively looking into the HD800S plus the EAR Yoshino HP4 which has been around for many years and potentially available demo/second hand.Let us jump into its' forte.
Percussion
Transient attack
Dynamics
Decay
While it is not music it is a demanding test for a hp. The HD800s can exactly locate the door knock. The sound explodes with no overshoot
The decay is perfect with no ringing.
These characteristic translate in drum solos. When the drum stick smacks the drum it is strikingly realistic. The bell is clear as well you know, a bell. There is no smearing. This alone is worth the price of admission
There is little or no fatigue. That depends on the quality of the music. It does not mask faults.
You want to search out your favorite recordings. I tapped my foot along with the music. I wanted to dance. Where appropriate the music started low and built to a cresendo.
The hp head no problem deciphering instruments and voices. They were kept separate and were easily located in space.
I am impressed.
While I am a music omnivore I do have my favorites.Thank you so much for taking the time to share your thoughts on the 800s with the Diablo.
I was particularly interested in the transients. Very helpful.
May I ask - did you listen to a variety of musical genres - or stick to one predominantly?
Awesome! Thank you very much. Presume you mean the Stax 009?Although at least one reviewer claims the Stax has been bested, they remain my standard. To my knowledge there are two $50k hp systems available. I doubt if I will ever get my hands on one.
The 800s does "bleed"some sound. Most headphones do when played loud. I don't it will annoy the person sitting next to you. The open back design does contribute to the overall ambience.
Yes. They on my wish list.Awesome! Thank you very much. Presume you mean the Stax 009?
Thank you very much for posting your thoughts. Gives me a great idea. Unfortunately where i live audition is not possible. So its a case of buying secondhand, trying and if they don't work out, on selling. Knowing the Diablo works well with them assists greatly.Imaging
The trend seems to a triangular image pattern for hp. Not so much for the 800S. While location of instruments is specific, the sound is diffuse giving it a natural quality. The imaging in binaural can be spooky if the recording calls for it.
Resolution
Detail
Dynamics
It does not resemble a close mic recording, nor is it laid back. On a scale of rows 1-10, it is a row 6 presentation.
There is plenty low level resolution. You can hear guitar players drag their fingers along the strings but not to annoying levels.
Symphony orchestral music is handled well.
Dynamic contrasts are good and it has no trouble when the music gets loud.
Overall performance
You can make your own decision about the price. I think it is good value. The Diablo increases its value making it portable and mobile. Clearly the mkkers did not anticipate that.
The HD800S is both musically enjoyable and reference quality. Distinguishing the quality of recordings is relatively easy.
The HD 800S is what a flagship should be. It is an easy choice if it meets your needs.
Highly recommend.
Oh. I should say a closed back version is available. If you want the signature version you will probably have to go used
