Awesome! Which tubes are you using? Most interested to hear and read more!I must say the HD 800s does love tubes.
Very interesting...I have heard [a few] say that once the 800 is modded and/or set up with the right amp, they marginally PREFER the original 800 over the 800S.I own the 800 and had the s a few times to compare
both are very good. the amp pairing is more critical then many other headphones. they are high imp and need some
output imp above 10 ohms
oddly this need makes such amps a poor choice on low imp headphones and very bad on IEMS. great review
I think the s was made to calm down setups not ideally suited for the 800 model. it does have great attributes over all.
Thank you and understood! We are focusing on nailing down the amp first, and then will turn to the 800S of which there appear to be quite a few on the demo/second hand market.While the HD 800s is not a snob it definitely loves to run with the big dogs. If you get my drift.
Found a reputable dealer who was having his own special sale on the last 3 in stock. Took the last one. Should arrive in 2 weeks. EAR HP4 2nd hand due to arrive later this week and then will have it picked up to go to EAR for a complete check up/retube. Getting there. Last thing is headphone cable...have spoken with Moon Audio. Extremely responsive and helpful. Likely to go with their Black Dragon cable...25 foot length. They felt confident if the amp drives the headphone as well as all the reviews, owners say...then there will basically be no difference between the stock 10 foot length and a 25 foot length. Altogether, while expensive, this still cost a lot less than just the standalone EAR retail by itself. We shall see. Very exciting. Thanks for all your guidance.Headphones.com is having a sale on the Senheiser headphone. Most notably the 820 and 800s.
At one time I was a headphone freakVery interesting...I have heard [a few] say that once the 800 is modded and/or set up with the right amp, they marginally PREFER the original 800 over the 800S.
Have you ever heard the 800 or 800S with the EAR Yoshino HP4 which has numerous articles, reviews, comments about how well they pair? The EAR has 2 output impedances (low Z and high Z)...10ohms and 40ohms where the latter is for something like the 800S, and I have heard, between its 'slight voicing' and its impedance, gently pushes the mids forward on the 800(S) and also bolsters the bass significantly in comparison with a number of other amps which also benefits the 800S.
I own the hd800 and had the 800s a few times it is nice but looses some clarity to my earsAt one time I was a headphone freak
I still own 5 pairs I keep. I use them as a reference on setting up systems
Thank you! You certainly seem to have some significant experience.I own the hd800 and had the 800s a few times it is nice but looses some clarity to my ears
for the 800 to shine you don’t need tubes but you do need a clean system feeding them
I suspect you set up your 800 headphones really well...which is what truly matters to get it right. Look forward to hearing it. Currently listening to HD650 and Arcam rHEAD which is for me an excellent headphone system (Cardas 20' cable).I had one fri come over with his modded 800 and after hearing my stock ones on my setup he removed the Mods at my place lol. in the end it’s about what you like. an example I own stax 009 and to me the 007 is blurred or a bit vailed. but this is my view and if I use the 007 For a day a day or two it’s fine until I put back the 009. some love super details some like a laid back sound
