And he could have for you in reverseLOL. I could have phoned that one in for you.
In the context of this thread, which I believe Greg started merely to highlight my first point above, all of this begs the question: does anyone believe this matter will be proven to anyone's satisfaction?
Mike not only have I not changed my mind about the demag but the responses were entiurely predictable. AMIR being the notable esception.
That's getting ahead of ourselves.First thing would be to show that a cartridge can pick up such infinitesimal reduction in magnetic field. Imagine using your simple voltmeter to read .0002 ohms. Not possible because the leads of the voltmeter has more resistance than that. By the same token, someone has to show that the cartridge output changes at all over its baseline noise. I suspect it will not. Because if it did, then the magnetic field from the motor would cause far more damaging results.
i suppose that WBF (and in particular 'General Audio Discussions') is mostly about expressing one's own views and dancing the dance of respectful interaction. so your comment is no surprise. i doubt that many here click on threads in the hopes that their mind will be changed today. (not that there is not an interest in learning, but that's mostly about new product or music).
and i'm not saying this is bad, unexpected, or that it needs to change. and i'm not saying that i'm any different than anyone else.
i'm not trying to de-rail the thread; and go ahead and delete this post if it is any sort of problem. it's only that expectations on side changers regarding a doubious tweak should be pretty low.
That was not meant as analogy to demag but rather, to demonstrate that just because you change the input of something (resistance on the ohmmeter leads), its output does not necessarily change. Hence my point that one needs to first prove that the 10% reduction in magnetism of the record will show up on the output of the cartridge. I don't have any data on how much magnetic flux there is in a cartridge and the minimum for it to create a voltage above noise. Does someone have that?your comparison with the voltmeter is not valid
LP may be closer to the part of the LP that it is playing. It is not close to the rest of it. Also, keep in mind that the same claims are used for CDs and cables, neither one of which works on the principal of flux conversion to electricity.Also the magnetic field of a dipole varies with the distance to the 4th power - it is why cartridges are not affected by the magnetic flux of the motor. The LP is quite close to the coils of the cartridge.
It has no effect probably because the magnet inside the cartridge is a lot stronger. If this were not the case, then the mere movement of the tonearm in the air would generate electricity. That said you are right that the movement of the LP accentuates that effect. Will it make 20,000 times more difference just to match Earth's magnetic field?As the magnetic field of the Earth has no effect, comparisons with it are out of scope.
That is the only measurement that is needed. If I have a magnet, I measure it the same way. We don't mix the characterization of magnet with how it will be used.The Furutec measurements only show something changes in the static magnetization of the LP - good for advertising, as they show something changes, nothing else.
Something tells me if this were so easy and true, then the manufacturer would have done and there would be a ton of other devices including some at $19.95Until now no side has provided enough technical evidence that the other is wrong.
Something tells me if this were so easy and true, then the manufacturer would have done and there would be a ton of other devices including some at $19.95.
It is interesting to not that the worse this became the lower the reviewer enjoyed the cartridge (seemed a more notable trend than any other measurement given such as crosstalk ).In practice, a pure horizontal modulation represents in-phase or mono (L+R) information [illustration provided in magazine].
The response and distortion of this recovered horizontal modulation influences the colour, focus and impact of the music's central image within the soundstage.
Vertical groove modulation carry difference (L-R) information which, ideally, should be recovered by the pick-up with exactly the same response and distortion characteristics as the those horizontal movements.
If not then the "character" of the reproduced soundstage will change from the centre to the edges.
By inference, the solid (L+R) and dashed (L-R) response traces should be identical, as should the solid and dashed distortion traces, if a truly uniform sounding musical event is to be delivered.
Only one cartridge truly got close to this ideal in our Group Test. It was not the best tracker, nor offered the lowest crosstalk, but our reviewer loved it.
That is for good reason. This will be the mother of all tests to conduct!I am having trouble following what the plan is with the testing lol.
You are right in general but not in specific...the bigger the claim, the bigger the proof.
This is intuitively correct but actually false. The quantum and method of proof is constant. The more we disbelieve something the less we are willing to accept the proof. Whatever it is.
If we assume that the people who have heard the difference don't have systems that suck without it, then we are compelled to agree that the difference heard is small.
So if anyone wants to test this, it should be for fun and not any attempt to create scientific proof. As audiophiles, that is all we should care about anyway.
As I noted earlier from a line used by Ethan, the bigger the claim, the bigger the proof.
As I noted earlier from a line used by Ethan, the bigger the claim, the bigger the proof. If we assume that the people who have heard the difference don't have systems that suck without it, then we are compelled to agree that the difference heard is small. As it should be with a 10% reduction in such small magnetic field. So characterizing it and making sure it is not variation from playback to playback is important. Seeing how delicate both the LP and cartridge are, we must rule out differences in successive playback in those. I would think the whole act of picking up an LP, putting it on the machine and taking it off might make the same small differences through change of temperature, how flat the LP is, the level of static electricity in it, change in distribution of dust and other particles in the grooves, etc.
I am not an LP person but I would think that if we bought two LPs, there is no assurance they are identical. So a test first needs to be run to determine that. Observer bias would be quite high there as one thinks that they should sound the same. I my book, a test where you play one LP, stop, and then play another LP is not going to product good results when the difference is tiny as would be the case between these LPs. The test then needs to be conducted on two identical playback systems. I know how to do this with digital sources. Not sure how to do that with turntables, putting aside the much higher cost of such a set up.
And the above is just to test the two identical LPs without using this device! With the device, the world gets far more complicated. Who is to say that the LP doesn't get remagnetized as soon as we put it on the turntable? If we don't understand its mechanism for how it performs its job, then it is hard to know how to make sure its characteristics are maintained, reduced or improved in the handling of it.
Now, there is another angle which is to test the people who hear big differences. That can be accomplished with your method of buying two LPs, treating one and not the other in another room and then playing them in sequence. I would think since the differences heard are said to be big and enough to convince anyone who listens, then stress of blind testing should not wipe it out. If it does wipe it out, then that would be another data point to have at least. BTW, if a preference is found, I would reverse everything and see if the effect is repeated.
Interested if anyone does do this, looks like only you at moment Mike hehe
Gary, let us know what you decide to do.
But if using specific measurements relating to the LP-cartridge, it might be worth considering my earlier post relating to Paul Miller's measurements on cartridges.
Thanks
Orb
I've always been pretty skeptical about demagnetizing an LP, so I don't own one. But if I can get a hold of one, I'll make recordings of the same LP pre- and post- demagnetizing. Then, the only variable will be groove wear (playing the LP twice in quick succession), power (your neighbor turns on the microwave oven), and operator bias (I make a better/worse recording because the LP has been demagnetized).
