In post # 3, Gary mentioned this:
"Every single tube that they receive (they do not manufacture their own tubes) are burned in for 120 hours before being measured and matched. They they are burned in again, to ensure that the do not drift. That is why Jadis amplifiers are not easy to bias - they should be biased when new tubes are put in, and then they should be left alone."
Does this mean that even for Class A auto-bias Jadis amps, there is a new to check bias when new tubes are put in?
How does the Class A auto bias function of Jadis work? Some tech told me that it is auto biased by installing matched pair tubes. Does it mean all you need are 4 matched pairs even if the 4 pairs are not balanced to each other (in an amp that uses 4 power tubes per channel, for example).
First of all, the workmanship quality of Jadis is excellent. The construction in 3D with copper rails can't even be built in a few hours. The polished steel case is amazing.
With cathode bias, the idle current is created with a cathode resistor(red) which is bridged with an electrolytic capacitor (alternating voltage).
The gridleak resistor(blue) ensures that no grid current flows on the grid of the KT 88. This is the protection against excessive current consumption (thermal runaway of the tube. This is the rough principle of how it works.
I'll explain to you using the yes 80 circuit diagram what the catch is.
1. Jadis saves one resistor + electrolytic capacitor per pair of Kt88 tubes.
This means that if they are not matched, there is an asymmetry with a pushpull amp. A slight hum is possible or wear on the tube is not the same in the long term.If you had used this combination per tube, this problem would not arise. my opinion.
2.The grid leak resistor has been chosen too large. If you look at the data sheet of a Kt 88, it says the maximum permitted values for the respective bias method. And now the vicious circle begins that leads to damage to the amplifier and tubes.
The only reason I can think of is that if you reduce this resistance to, for example, 150kOhm to be on the safe side, this means that the ECC 83 driver tube is being put under too much strain and the amplifier no longer sounds good.
Unfortunately, too high a grid leakage resistance leads to uncontrollable failures. As I said, it doesn't have to happen, but it can.
I hope I explained this somewhat understandably
