Forgive me if this has already been discussed, Ron, but to state the obvious: why not try an Apex with your speakers?
Apex, meaning in this case?
Spot on Al, there would be very few rooms that could take 100db without a massive increase in reverb in which case you have no idea how the components are performing. In all these discussions about amps, efficiencies and topologies the elephant in the room is ... errr ...the room.Another thing to consider is that rooms also can run out of headroom. What might seem like compression may, in some cases, actually be room distortion at the high volume played at. I have experienced this myself, only knowing about it in hindsight after I further fixed the room.
Candidly, you’ve done the same in my room!Interesting, Al. I don't know, with the adjacent equipment room acting as kind of a SPL vent which almost doubles the interior cubic footage I'm skeptical it was the room.
Phil was playing so loudly I was nervous he was going to blow the drivers.
Cheever lol.Geddes and Cheever (and others, dating back to the 1930s) have found that there is essentially no correlation between THD or IMD and subjective sound quality. The composition of the distortion is far more important than the amount.
Toss into the mix you can get a BACCH with room correction software now. And some are selling their MSB Select to just use the BACCHs internal DAC.I can play symphonic music cleanly (without reverberant field smearing) at 100 dBC peaks. But with orchestral music, I tend to set volume so that low energy sections are clear … and I let the high energy sections fall where they may. The room is about 500 square feet with 10 foot ceiling, and I’ve incorporated diffusion, diffraction, and absorption features. I am actively wondering how much clearer things would be with Alexx Vs, or some other larger speakers, but I am very happy with the clarity of the Sasha DAWs.
I do not use room correction in my two channel system. The HT room clearly benefits from it. But I can’t bring myself to try it in the legitimate audiophile space. When people post recordings of their systems, I often get the feeling that they’ve got done equalization that is enhancing the midrange… but it is just speculation.
AJ that's a pretty decent room size I assume you have quite a bit more treatment than Ron to achieve a clean 100db ?I can play symphonic music cleanly (without reverberant field smearing) at 100 dBC peaks. But with orchestral music, I tend to set volume so that low energy sections are clear … and I let the high energy sections fall where they may. The room is about 500 square feet with 10 foot ceiling, and I’ve incorporated diffusion, diffraction, and absorption features. I am actively wondering how much clearer things would be with Alexx Vs, or some other larger speakers, but I am very happy with the clarity of the Sasha DAWs.
Never got to hear that one. It is not SET but is a circlotron, which is usually used in OTLs like Atmasphere or Joule Electra. The KR has output transformers though. It uses a lot of 842VHD output tubes, so will get very hot.Hello Brad,
What is your opinion on the KR Audio VA200?
Lest we forget a more recent implementation with the Aries Cerat lanus line of pure class A Circlotron / TriodeFet amplification Viz the Geminae .It is not SET but is a circlotron, which is usually used in OTLs like Atmasphere or Joule Electra.
Agree - one should follow his/her heart ??!Not obvious at all, so nothing to forgive.
1) Pendragons do not need that much power.
2) Not once in my life have I ever cared for the sound of any solid-state amplifier on any electrostatic panel or on any planar-magnetic panel or on any vertical ribbon driver.
In this hobby most follow the ears, sometimes the wallet
And sometimes from the Blind Idolatry Of Another !In this hobby most follow the ears, sometimes the wallet
Haha - according to ’Roxette’ you should ”Listen to your heart” !In this hobby most follow the ears, sometimes the wallet
