You can't go wrong with aries-cerat components.
There is no rule that using less parts means you can use better parts. Tubes are always related because of how they work with linear distortion. Negative feedback is not off/on and can be very varied amounts.
Sounds great, Ron wish I was nearby.AUDIO PARTY TODAY IN BEVERLY HILLS!
I'm having a big audio friends event at the house today to demo the Clarisys speakers and a new Aries Cerat preamp.
I think you would really enjoy hearing the system if you can swing by between 1 PM and 5 PM!
Text me at 310-880-9000 and I will immediately send you the address!
Hi Ron,What are your detailed impressions?
To which preamp did you compare it side-by-side in house?
Why didn't you keep the Incito S?
Incito S versus Aesthetix Callisto would be a fascinating comparison, too!
Just one reminder. I think AC preamp output 180 out of phase. Better double check.
Of course with less parts you will be about to get the best parts more easily.
Are you saying 12 KT88 or 6550 will sound similar to two 300b?
Yes. It is funny that some people accept and love the idea of using tubes in parallel at input stages to lower noise and get upset with the idea of using power tubes in parallel.
Surely the equivalent plate resistance becomes lower, a good thing in my opinion. Others prefer the "magic" of low damping factor, that surely can be useful in particular cases.
Interesting. I remember that in the early 90's Atmasphere also sold some autotransformers packed in a nice wood box that increased impedance, allowing us to use the lower power M50 OTLs with speakers of low impedance.
That would be Paul Speltz's autoformers.
Increase Speaker Impedance – ANTICABLES Autoformers & Zero Boxes
ANTICABLES ZEROS make virtually an amp/speaker combination work well together. Our Transformer / autoformer increases speaker impedance for THE BEST SOUND!anticables.com
Hi @morricab ,View attachment 144336
Incito middle rack and Protos bottom rack.
I think their digital streams on Qobuz sound at least as good as the vinyl, which are not the best pressings. My favourite older ECM LPs, in contrast, sound much better than digital.Hi @morricab ,
How do you find your ACT records?
I see you have one down in the right corner of the picture.
/ Jk
Thank youI think their digital streams on Qobuz sound at least as good as the vinyl, which are not the best pressings. My favourite older ECM LPs, in contrast, sound much better than digital.
If you have both current and Voltage feedback in the same amp its possible to vary the output impedance without affecting gain or distortion of the amp. Fisher and ElectroVoice did this in the 1950s before the Voltage drive rules for loudspeakers became accepted.There are limits to low damping factor. You can make a current driven amp that'll delaminate and shoot the driver cones across the room if you so desired. It certainly is not an endless benefit. Frankly some of these tube setups sound so much like mush the instruments are not even identifiable but maybe it sounds more like vinyl, even while playing vinyl, than another one?
Depending on the amp you may not have needed them. The ZEROs, like the earlier ZMusic autoformers, were/are meant as problem solvers. But if the amp can drive the speaker directly they are not any help. Our OTLs can drive ESL57s and ESL63s directly so I would not recommend either autoformer for that purpose.Which when applied respectively to my pairs of Quad 57 , Quad 63 , Quad 2905 and lastly Martin Logan CLX Anniversary resulted in nothing discernibly positive , whilst producing an overall dampening effect on dynamics etc . My pair were ‘’Naked’’ Zero’s . They were moved on which was a shame as I had high hopes based on no little due diligence before hand. As ever YMMV etcetera .
Yes. I've not seen a set of those in decades. They gave our amps the ability to drive a 1 Ohm load. I heard a set of our early MA-1s using them to drive a set of the now ancient, 1 Ohm Apogee Full Range speakers at a reviewer's house and they worked just fine.No, I was addressing the original Atmasphere Z-music autotransformers, I owned them with the MA50 and when I got the MA2 I sold them to Paul Spetz, as I was not needing them anymore. The current Zero's are toroidal, as far as I remember the Atmasphere ones had EI cores.
