Cutler Hammer was bought buy Eaton. I have the same system..commercial.They are Eaton bolt-on breakers.
You need to roll the tubes to quieten it and Mook it like Greg baron has. Write to him.
At Greg Beron's client yesterday I counted fifty (50) big Mooks. This fellow has everything Mooked. There are Mooks underneath every component and there are Mooks on the tops of components.
Greg also explained to me in detail his suggestions for replacing the stock tubes on the Io. I have a lot of expensive treasure hunting for NOS tubes to do!
Are you going to "Mook" the American Sound?
Greg's client's Clearaudio Master Innovations sit on three big Mooks. I will not put Mooks under the American Sound.
You need them under the IO. It is ok to be stubborn though![]()
I am not meaning to be stubborn. I am open to Mooks under the Io.
But I would bet that the Herzan active isolation platform under the Io would make a bigger improvement.
Probably. But I would not bet on putting it under the AS2000 turntable so easily. The compliance of the pressurized air layer in the platter air bearing creates a resonance with the high mass platter of unknown frequency - how can we be sure that this resonance will not be excited by the servo mechanism of the active table?
