Took one both from this program and my preferred one- Audiotools. I find the latter much, much better fyi. It's 49.99 though.
Look quite identical to me.
Keith-I have posted numerous pictures and videos of my room and I have a bunch of room treatments hanging in my room.
I thought audiotools made his room look worse.
The scale is so bad on audio analyzer, hard to say whats going on.
It's obvious that the two readings you posted are commensurate, and describing the same room, while one actually doesn't describe the entire range up to 20kHz, and that's your preferred one.
I use Analyzer on an iPad, and find it quite useful. Have a number of other apps, as well, but this does a good job of pointing out "what's what."
my guess is since bass trapping is involved ... that mids and highs are much more clear.
Coolio. Please post a link....not on your profile.
I did some filter outlay and measurements today(...)
Why not, it doesnt matter anything for the FR tolerance i want to see , plus it looks nice to have the graphic a bit high , i think .
I can post a different scale if i want but the tolerance stays the same
especially for micro , on a 35 db scale and also 1/6 octave smooth factor (...)
Another time micro, i ll come back in this topic , when the filter is finallized
As i said before due to room influence the measurements under 300 hz are not to be taken serious , thats why the parameter menu is there .
Do you have the FR of your speaker /room on a 35 db scale , 1/6 octave smoothe factor ???
REW (free) + an USB Soundcard with phantom power such as the M-Audio or the Tascam US-122MkII (75 to 140) + a calibrated behringer ECM-8000 (80) combo is the real deal. It will not take more than a few hours to get result with and improve many systems.
Happy Easter people!
I've used REW + Tascam US-122 MK2 (and US-144 MK2) + calibrated Dayton EMM-6 (and Behringer ECM8000) with no issues.Has anyone here actually tried the REW + Tascam US-122 Mk2 + calibrated Dayton EMM-6 combo and got it working? I'm about to pull the trigger on this stuff and although it looks like I should be good to go, a little reassurance in this area wouldn't go amiss...
