I've used REW + Tascam US-122 MK2 (and US-144 MK2) + calibrated Dayton EMM-6 (and Behringer ECM8000) with no issues.
I thought that would be the case, but appreciate the reassurance. Thanks!
Change out the EMM-6 for UMM-6 and you don't have to worry or buy the Tascam. Its noise floor is higher but doesn't matter for this type of analysis.Has anyone here actually tried the REW + Tascam US-122 Mk2 + calibrated Dayton EMM-6 combo and got it working? I'm about to pull the trigger on this stuff and although it looks like I should be good to go, a little reassurance in this area wouldn't go amiss...![]()
I was just wondering what the Tascam does and where it fits or why it is even needed
It does several things:
1. Supplies 48V phantom power to the mic.
2. Provides a way for the mic's signal to get into the measuring laptop while bypassing the usually iffy laptop mic input.
3. Provides a way for the computer generated tones to be connected to my amp.
As a bonus, it also has a couple of MIDI sockets, which are used to connect things like synthesisers and other keyboards to a sequencer.
Edit: This page has a good explanation, near the bottom is the set up I'm going to use. http://www.hometheatershack.com/for...ards/10001-rew-cabling-connection-basics.html
and if you buy the mic Amir recommends, then you don't need it......what's there to think about
5m is within USB cable max length so should work. I don't know how long the cable is that came with it but is pretty long.Amir,
Can the UMM-6 be used with a 5m USB cable? One of the nice things of my setup is that I have a 5m XLR cable and moving the microphone in the room does not oblige me to move the computer. Although getting rid of the EMU USB box would be very nice, I use it also as an audio spectrometer to check my equipment and tube quality.
No analog level control. However, the latest REW version is supposed to be able to use the sensitivity setting in the calibration file that comes with it which eliminates the need to find the reference. I personally don't care about level calibration for room optimization so have not bothered to check this out.A naive question - does the UMM-6 have an analogue volume or similar control? What is the 0dB level?
The one I recommended just came out in the last few weeks. Prior to that, the only solution was what was proposed with outboard USB adapter. It sure makes things simple to use and a lot less components to plug in, power up, etc.and if you buy the mic Amir recommends, then you don't need it......what's there to think about
As far as I know, it follows the sampling rate as set by the OS. Likely though it won't go above 48 Khz though.Thanks - do you know what is the sampling rate and bit resolution of this mic? I am convinced - all I need now is to find some one supplying it in Europe!
BTW, here is a useful comparison chart of the *noise* floor of each mic:
The UMM-6 looks ugly there but note that its noise is at -70 dB. As long as you put 30+ dB into the room above that, you should be fine. Hopefully someone will make a cleaner version of this in the future.
It is not my test so I don't know if he calibrated to 0 dBFS. The graph is from the guy at Cross-Spectrum who calibrates these mics.The 0dB is the digital clipping level? Do you know why there are such a high level of 1kHz harmonics in all the spectra? Can we assume it was a problem of the particular PC used for the measurements?
They are not saying that they have dynamic range of 130 db but rather, that is the maximum SPL they can handle. Here are the specs for UMM-6:I am astonished that the EMM6a, inexpensive if we consider the typical prices of instrumentation microphones, can have a dynamic range of almost 130 dB between 1 and 10 kHz.
I hear youThat noise floor graphic was one of the things that convinced me to go the EMM-6 route. I'm not made of money but the difference in price between the two approaches wasn't enough for me to forgo the EMM-6/Tascam US-122 route, especially as this is a one-off purchase.
