Yeh right. Asking me questions whose answers were clearly in that thread. Half a dozen objectivists grilled me in that thread. People can read it for themselves.
As for you, I banned you from ASR Forum for your non-constructive, antagonizing, personal bickering and fighting style. I am not going to now sit here and answer you back and forth when you are not forthcoming with a single thing I asked you.
Go outside and enjoy the weather. And by chance if you actually listen to a stereo system, do as I am doing right now and listen to some music. Otherwise, unless someone wants to ask me about the same thing, I will leave you to yourself to suffer from lack of answers from me.
jkeny said:
Aha, you run when you have no answers & the inconsistencies pile up - your technique here is shot full of holes which I'm exposing & rather than face up to this you become ad-hom as a means of avoiding answering these.
So what we see demonstrated here, Amir (apart from your usual tactics) is:
- A claimed technique for dealing with level matching which has no basis in audio science - which you pretend to be a stalwart of.
- has no evidence to support your claim that it does what you say it does - deal with level matching bias
- is shot full of inconsistencies & logic flaws - like your claim that you need a multichannel volume control for level adjusting two DACs
- inconsistencies like your claim that it is double blind - it's not even blind never mind single blind - it's basically a sighted test which you denigrate - you are self scoring, Amir as you claim others are doing
- inconsistencies like your claim that you didn't want to change "things while conducting an experiment." - you are introducing multiple variables instead
It's a regular occurrence now, Amir that your efforts fail to pass muster when examined - evident here & evident in your many measurement fiascos.
You present many graphs & measurements (but none in this case) which you use & which fool some people, some of the time.
On closer inspection, when your mistakes are exposed, you avoid explanation - instead using ad-hom tactics as a deflection & avoidance - this is just another example
Hello gents,
My preference has been to be part of a forum in which things are called out for what they are.
To me, there’s a significant difference is using observation in the facilitation of hypothesises, experimental methodologies and data to explore phenomena that are not well understood (neurobiological perception of a time-based modulating art form), versus using observation in the facilitation of hypothesises, experimental methodologies and data to explore phenomena that are well understood (the human hearing mechanism) solely in order to avoid potential cognitive dissonance apropos nascent phenomena that are currently not well understood (i.e. the former).
The latter is an example of what Daniel Kahneman calls “fast thinking” and the way consciousness is wired toward producing instantaneous responses to problems -
not because they are the most appropriate or valid response, but because they are responses that most closely meet pre-existing systematic biases that are then justified via a process of selective rationalisation, and then often given alternative monikers such as “truth”, “facts” or “science” in order to double down on that bias. Nevertheless, that such bias exists, and has been extensively documented and researched for over a thousand years (1) prior to Peter Watson first coining the term “confirmation bias” in 1960 (2), fundamentally negates any pretension to credibility, no matter how emphatically those who adopt its pretence may claim otherwise.
My observation of Amir here on this forum, and indeed, many others he’s been a part of, is that his conduct, like many if not all of us, is governed primarily by inherent biases that are often neither acknowledged nor eliminated (3). Let’s be clear: Acknowledging and eliminating our biases is not easy, especially when dealing with a complex subject that encompasses a hugely broad and interdependent matrix of well-understood phenomena (say, the Laws of Thermodynamics) and not well-understood phenomena (say, why our brain has specific, independent neurobiological pathways for music that do not interact with pathways for other sounds nor speech). We are constantly attempting to articulate a phenomena suspended between these two realities, and our perception of those phenomena is ultimately what we bring to any discussion here. The results? Well, we can all see for ourselves.
Like I say, I’d prefer to be part of a forum that uses
all the research available - the stuff that’s well-understood and documented and the stuff that’s not well-understood and documented that gets discussed and debated
with as little bias as possible, as much as that may cause the sort of gaps we occasionally plunge into. But, in my perspective - limited as it is - no-one “wins” when not well-understood research is rejected
a priori simply because it causes cognitive dissonance for those whose preference is to hang onto pre-existing biases, and especially, those who when challenged choose a path toward deflection, re-framing of the argument and/or forms of personal pettiness and cries of victimhood.
But that’s just me.
853guy
(1) "...for it is a habit of mankind to entrust to careless hope what they long for, and to use sovereign reason to thrust aside what they do not fancy.” Thucydides (460 - 400 BC)
(2) “Cognitive bias” was coined by Amos Tversky and Daniel Kahneman in 1972.
(3) Notice I write that my comments relate to my "...
observation of Amir here on this forum, and (...) his
conduct...", not of him personally, whom I have never met, and only ever related to via this forum.
