ThanksCongratulations! Can you post any photos? Ho many cards do you have for it?
That is why I sold mine. I would go tube now with an active analog xoverI have heard 3 mega horns with Accuphase filter now, their tone just didn't work, totally undid the magic. They had very good top to down extension and rest of the stuff as they were complex multi-ways
I'm not actually defending the XVR1, as I've never heard one, but by I've never seen a bad review and a quick look at the internals shows that they are very different designs. I just don't think you should dismiss it out of hand based on your experience with the PAP version.
I am quite happy with F25 which give very musical sound.
But I had never tried Pass XVR1.
Maybe I will not try Pass XVR1 in the future since I am rather disappointed with Pap C1
One can do 4- channels, but then you’d need a second control unit that can be powered by the same PSUIn a 2-way wold, yes ! If you are thinking 3 or 4-way the F-25 is the thing to have. But you will need to know what crossover points you are aiming for…
Yes I know, have done that back in 2004. But the price…! and a second unit will only bring you to 3-way.. for a full 4-way system you’ll need 3 units an maybe one more power-unit. Makes you car look inexpensive.One can do 4- channels, but then you’d need a second control unit that can be powered by the same PSU
I believe you are talking about this one. Compared to all the other solutions mentioned here it's super cheap, but still... Designed by Papa Nelson. Worth giving a shot if you can assemble it/have someone do it. It is a super simple solution, no feedback. It would go with SET amplifiers like a dream!I'm not actually defending the XVR1, as I've never heard one, but by I've never seen a bad review and a quick look at the internals shows that they are very different designs. I just don't think you should dismiss it out of hand based on your experience with the PAP version.
It does seem like PAP really charge a premium for that little guy, I was shocked at the price total given what they charge over at the DIYAUDIO store for pretty similar looking crossover kits also designed by Nelson (a couple hundred for the full build).
Indeed. There's both that one and then the newer 6-24 option: https://diyaudiostore.com/collections/crossovers/products/diy-biamp-6-24-crossoverI believe you are talking about this one. Compared to all the other solutions mentioned here it's super cheap, but still... Designed by Papa Nelson. Worth giving a shot if you can assemble it/have someone do it. It is a super simple solution, no feedback. It would go with SET amplifiers like a dream!
Oh, that's cool too. I've seen those simple J-FET buffers in so many audio pieces of equipment...Indeed. There's both that one and then the newer 6-24 option: https://diyaudiostore.com/collections/crossovers/products/diy-biamp-6-24-crossover
"The DIY BIAMP 6-24 kit is a stereo analog active biamp crossover circuit designed for high flexibility. Featuring 12 discrete Jfet buffer circuits operated without negative feedback, it offers 16 continuously adjustable filter elements in two low-pass and two high-pass filters with slopes of 6, 12, 18, or 24 dB per octave and various “Q” characteristics. It has flexibility not generally offered by crossover products have “textbook” characteristics, allowing more detailed tailoring of filters around the actual character of different loudspeaker drivers."
This is a very confusing comment. It sounds like you want a full range driver, no crossover, active or between the amp and driver. If you try to go without a crossover, you have distortions, so your back to a crossover. And around and around we go.I've been asked a lot about electronic crossovers by customers over the last 45 years or so.
IMO/IME the more transparent your system is, the more you can hear what they do. I regard them as detail and bandwidth filters. For this reason I prefer speakers that allow me to run the amplifier full range on the loudspeaker, as so far that has proved out to be the most transparent. I know a lot of 'full range' driver people hate the idea of a crossover in front of their (usually really expensive) 'full range' driver, but the simple fact of life is that any excursion of the driver caused by bass notes for which the driver isn't coupled into the room (and even if it is, but to a far lessor extent) causes very audible Doppler Effect distortion, which causes the driver to sound harsher and less detailed. That's the opposite of what you want out of such a high quality driver!
If you somehow limit the excursion by placing the 'full range' driver in a box that acoustically limits its bandwidth, you still have to deal with the fact that the out-of-band bass notes are heating up the voice coil, causing thermal compression.
So you simply have to have a crossover, since all 'full range' drivers are really just wide band midrange drivers, part of a 3-way system if we're all being honest. The best place to put that is between the amp and drivers, no doubt why 99% of all loudspeakers made use this technique.
We ran a high end crossover (balanced, all-tube) at a show one time (RMAF, about 10 years ago) with the intention of bi-amplifying the Classic Audio Loudspeakers T-1s that we were using in a ballroom-sized room on the first floor. I have recordings that I use for test like many audiophiles; some of them are recordings I made and released on LP so I know how they are supposed to sound. The simple fact was the crossover was losing detail; when we got it out of the system and ran the speakers full range the detail and bass impact returned. I know this is anecdotal but FWIW I've seen this played out a lot. No doubt you can probably get an electronic crossover to work fairly well, but the question is how well would it work if the speaker could simply be driven full range?
I will eventually try a tube xover from Marchand as an analog active. I had an Accuphase F25 in the past and while good, it was not totally to my liking in what it did to the tonality of the system.This is a very confusing comment. It sounds like you want a full range driver, no crossover, active or between the amp and driver. If you try to go without a crossover, you have distortions, so your back to a crossover. And around and around we go.
I removed all the crossover cabling from my PAP and drove the Voxativ direct from the amp. The most amazing violin I ever heard. As soon as the piano and singer started, it all went kaplooie. So I have a crossover. I have not found a way to get rid of it.
The reason it sounds that way is I was trying to help a local customer out with his foray into 'full range' drivers. He was not good on taking advice from schooled engineers and was religious about No Crossover. Over a period of three years I kept telling him he was going to need one. Had I not known him for 40 years I likely wouldn't have put in the time. My experience is the same as yours.This is a very confusing comment. It sounds like you want a full range driver, no crossover, active or between the amp and driver. If you try to go without a crossover, you have distortions, so your back to a crossover. And around and around we go.
That's exactly what the AER pnoe did very well, played the whole range without a crossover but too expensive. Maybe feastrex also can
Acoustat panels did full range very well...different tech but they were indeed full range (I got 20hz in my room with the big Acoustat Spectra 4400s). Other than a somewhat low sensitivity it is the best full range driver in existence I think...driving them directly with an OTL (their first iteration was just that kind of direct drive...same for Beveridge) is supposed to be one of the best sounds one can get...minus perhaps horn dyanmics.The reason it sounds that way is I was trying to help a local customer out with his foray into 'full range' drivers. He was not good on taking advice from schooled engineers and was religious about No Crossover. Over a period of three years I kept telling him he was going to need one. Had I not known him for 40 years I likely wouldn't have put in the time. My experience is the same as yours.
'Full range' drivers do not exist.
Anyone that tries to run them sans crossover will find that only certain types of lightweight music without bass can be played properly. For that they can do quite well although the highs will be beamy (you need a tweeter too).
For that reason I've come to the conclusion that the Holy Grail of doing everything with one driver and no crossover is a fool's errand- a Sisyphean task. It simply won't work, physics and all... people that don't like hearing this will do well to pay attention anyway. Honestly I see no reason why a skilled engineer would pursue the design of a 'full range' driver when its obvious it simply isn't going to work (I don't see the point in going over probably about 6"). But I can see plenty of reason to use such a driver in a speaker that employs a crossover, such as some of the Spatial Audio or PureAudio products.
