SET amp owners thread
According to the distributor for Europe, no one knows the answer to this, as there haven't been any failures as far. Note this is provided the GM70 tubes used in SET42SE will bias a tube and unmute the outputs! Amplifon sells selected pairs, but you know how audiophiles are, @christoph and myself included, we'll try and roll anything, and we've occasionally tried a GM70 the amp would flat out refuse. It may be that the biasing circuit has a narrow window, but again when a, tube is good to go it's good to go. My SET42SE has a little over 1000 hours on it, and I probably listen to more music than most audiophiles (unless they're leaving the system on and aren't listening attentively, which I do not do). Note the data sheet claims 1000 hours minimum at full power (where minimum refers to warranty for a military product). Can't say I'm surprised there haven't been any failures yet, as the amp has been on the market for fewer than 10 years and is built like a tank (or probably more to the point, given the designer's background, engineered and built like military radio equipment).
Greetings from Switzerland, David.
I know other Amplifon amplifiers and they are well made if I may judge. If you operate a tube at 70% of its anode power dissipation, it will last a very long time. If you get close to the 100% mark, it will drastically shorten its lifespan. Now you have to decide whether the difference in sound* is worth it. With the GM 70, replacing tubes is not expensive. With other tubes, I would forego a few watts of output power in order to enjoy the tube for a long time. my opinion*if there is any difference in sound at operation point.
That's certainly true. From all I know, GM70 sound best driven hard, with the possible exception of the copper plate version. Having said that, I know an Amplifon owner who runs his with copper plate GM70 without any problems.
The DIY GM 70 amplifiers I know usually run at 1100-1200V and with 85-90mA quiescent current (22-27 watts) are excellent. Up until now there was no desire to squeeze out the tube.
The distortion will certainly go down a bit, but other factors will play a role, e.g. how good the driver tube is.
P.S
If you don't want to mortgage your house, then sacthailand they make excellent quality.
While I don't doubt anybody's happiness with a SET setup, I would still hope that at least some of those who are 'satisfied' could be curious to know ways to take that SET sound to a higher level. What has been said about 'ease' at all sound levels is true - an SET gets obviously congested and constrained when being pushed too hard. The lack of those constraints really have to be heard to be appreciated. This isn't about measurements - it is just subjective and rather obvious audible shortcomings which take their toll on subjective 'realness'.
I would hope that people would not stick their heads in the sand if, as seems to be the general spirit here, there is a constant quest to make something which is already good into something which is great. BTW, I'm not selling anything or represent anybody but myself, so don't come after me for trying to sell you a product. ;)
Hmmm... I don't think I see many sticking their head in the sand on this forum. Most of what I read is all about moving something which is already good into something that is great. It often takes the form of debate between different points of view which sometimes gets heated as each side tries to make their point. The way I read @the sound of Tao's well conceived post is that he was just saying sometimes enough is enough of the same rhetoric.
Healthy debate is constructive and as you say it is a quest. It's hard to tell sometimes when enough is enough but I agree that sticking our heads in the sand does not move our understanding forward. It's all about the tone of the commentary I would say.
Reactions: the sound of Tao
I’d definitely think SET ownership is dominated by people who largely trust in their listening experiences and weigh more heavily on their subjective listening evaluations than other parameters.
Anyone who has walked into a brick and mortar store in the last 60 years has done exactly this. That is what has kept them in business so long. IOW that's the majority of the market- the 'measurement only' community is a small fraction overall.
With large horns very much effortless scale is the big thing… along with real immediacy… I love big ribbon panels as well for they also have a potential less fettered sense of realism but the dynamic freedom that full scale horns can deliver is something else again for me.
With low powered SET coherence and realism with acoustic instruments and a good SET with the right drivers do both flow and fine resolution.
You might want to hear what those horns can do when you drive them with a musical amp that has greater usable power. With any good system, you want the power amplifier to be loafing, having a lot in common with sitting on a park bench. To give you an example, think of any stereo LP that really brings home the realism. That LP was cut using amps that likely never got past 10% of their total power, and those amps were not SETs but instead if tubes (as was in the case in 1958) were pentode amps with feedback. But the cutter head has a feedback winding and typically this was applied to a 30dB feedback module that wrapped even more feedback around the cutter amp. That continued with solid state cutting systems.
If you're asking what happens when you drive a cutter head with no feedback, the answer is you lose a lot of stereo separation due to how the cutter mechanism is suspended. The feedback helps fix that, as well as vastly reducing distortion, apparently without causing brightness.
We tried using a 300b SET to drive our cutter head. We also tried a refurbished Dynaco ST-70 and also our stock cutter amps; the same track cut three times in the same lacquer. The cutter only needed a little power so the 300b SET was not being pushed hard. But it was the least musical track on the disk. The ST-70 and stock 1700 series solid state electronics sounded remarkably similar. The cutter head only needs about 3 Watts (about 7 Watts will fry it) and is an easy load (about 10 Ohms). The stock 1700 cutter amps make 125Watts at full power. So you can see that the idea is the system is immune to overload. The weakness of course is its very easy to fry the cutter head.
Ralph I do genuinely feel that you see the SET negatives way more than you see any of the positives… in fairness it forms the consistent message and dominant approach that you tend to bring to this thread. Providing technical insights is great… it’s sharing technical subject matter expertise which is valuable but it’s just part of the story and we can learn different things from those who actually choose SET over other choices.
I think it’s great to have people bringing a range of technical knowledge and I’m a fan of reading the technical information that you and others here bring to the forum… its also reassuring that the strong technical bods don’t always agree with each other and that even with objective technical interpretation it’s not all black and white.
This might be because I've spent more time studying them.
You're correct- SETs have more cons than pros. So you can trust your feelings in this case. I don't think there's much of a technical range of knowledge being expressed on this thread beyond Ampexed and myself. I don't see much in the way of EE talent here. I have seen Brad trot out some debunked 'studies' that don't hold up- that's not good enough if you want to get at the truth of the matter. Ampexed has a good solution if you really want to hear what an SET does right (which is to say, not bass).
The thing is, I'm not the one who came up with the cons. They just happen to be engineering fact; the lack of inductance in the output transformer limiting bass is a good example. When you compare any SET on a speaker that can play bass with an amp that can really play bass you hear right away what I'm talking about. Its not subtle- you hear it in 5 seconds flat.
Now I get that engineering might have a bad name around here. But please keep in mind that engineering is why SETs exist in the first place. There's math behind it- the 'why' of why it works. That same engineering provides an access, if the rules of human hearing are being observed, to build better amps. You may have noticed I've mentioned something called a 'quadratic non-linearity' when talking about SETs. That is why they produce the prodigious 2nd harmonic. That's the math and the engineering- how that works with the rules of human hearing understanding is we know the 2nd and 3rd harmonics add richness to the sound (because the ear assigns tonality to harmonics- its the same reason you can tell the difference between a country fiddle and a Stradivarius) and they can mask higher ordered harmonics.
I've also pointed out why so many PP amps are not seen as all that musical- and what to do about it, such that an SET wouldn't keep up in any way. I suspect some that have been attacking me missed that part. Search on 'cubic non-linearity' on this thread.
What I find adorable is people talk about the SET listening experience as if somehow I don't also listen and not heard SETs for myself.
maybe people more focussed on coherence might just set themselves up more simply
FWIW Dept.: If you want greater coherence, keep bass out of the SET. Same thing if you run a 'full range' driver for a speaker- keep the bass out of it. The reasons are different for the two but the result is the same- along with smoother sound with greater detail; this is easy to hear and not subtle! Its easy to blend a sub if the sub doesn't make any output above 80Hz as it won't matter where it is in the room if you can hear it at the listening position. If the sub goes higher than that you may have to position it with the main speakers.
My position throughout this thread is- if you want to use an SET and are dead set that's what you want to do, fine; I've provided some tips how to get better sound. I figure if you want even better sound, why not go for it??
During the course of your “Educational” lessons , delivered with more than a Whiff of condescension , does it ever occur to you that many SET amplification owners are not uneducated in the science behind their choice of said amplification , its technical Pro’s and Con’s , together with the Does and Don’ts of received wisdom in the deployment of SET amplification.
I like how he feels like he claim I use "debunked " studies and mentions me by name...knowing full well that he has me on ignore and so I can't respond. Nevermind the fact that he doesn't bother to say who supposedly debunked those studies. He for sure didn't!
I just prefer 2 way passive crossover and prefer SET and really not wanting to biamp either. I’ve tried biamping with different amps and also bringing in subwoofers with different amps in a couple of setups… and if I do try out subs again I’d aim to use a matching amp to the main amp I’m using… the trade off with coherence has always been greater issue for me. I do figure it’s an area I’m sensitive to.
Thanks Ralph it’s different preferences… thinking maybe you stick to doing you and I’ll just keep on my own trajectory.
Reactions: morricab
Please don't forget there are others listening and learing. I have wanted to try SET like 2A3 but that seems like they would never work with my speakers. I have an 845 that I don't understand why its so noisy. I thought about biamping but I agree different topology or tubes are hard to blend.
This thread isn't just about a few people saying they love SET, even if that means they love the sound SET distortion makes.. anecdotal experience is.great. understanding the math is also useful.
Seeing what speakers peoople are able to attach.to.SET and what they hear is interesting.
Fact is not condescension.
The M.O. is if you're going to post about something engineering/technical you always have to be aware that there are others who are also educated in the art. So you have to make sure what you say is accurate. I noticed I'm not getting pushback around the issue of the lack of inductance at low frequencies. That's a fact so is beyond debate...
One of the first times I heard your speakers (if they are the same as in your avatar) they were running a Whammerdyne 2A3 amp full range, in a smaller hotel room before AXPONA moved to the convention center. They were playing a favorite band of mine, Porcupine Tree. Their earlier LPs are nicely recorded and benefit from more power. I've used them for demo many times at shows.
Its no problem getting a PP amp to blend if you're careful with the levels (pink noise is very handy for that) and you consult with Pure Audio Project to get the crossover right.
You think I could blend my Blade with say Ayre SS on the woofers. Active analog crossover to set gain.
I think you also have to be really committed to venture down the relatively unfamiliar SET path. Far fewer dealer, displays and you have to understand sensitivity, loudspeaker matching to even get it work correctly. You cannot set up a Wilson Sasha or even some awkward bookshelves (the Magico Mini immediately comes to mind) with a 1 watt SET and hope for the best.
And since many low-wattage SETs are paired with horns, your commitment also probably relates to space. Full range horns start from BIG and get to MASSIVE. Even hybrids with big cones for bass are not that small.
Having finally heard a horn that intrigues me 2 years ago (the AG Trio G3), I could imagine how well that works with the Ongaku. But again, the floor area of the AG Trio G3 with its dual horns is nearly 5x that of the big Wilsons. just over 8 square feet vs 40 square feet or so.
That is all fine. People make there choices and do not need to be told by others that they would do something different.
BTW, the Magico Mini II is a beautiful stand mounted speaker that can sound excellent when properly set up and driven by the right amps. Certainly not a speaker for SETs. I loved those speakers and owned them for years. They simply represent a different approach.
If you consult with your speaker manufacturer, perhaps.
One thing you do have to sort out! As far as I know, your speakers are Power Paradigm devices as the manufacturer is happy showing them off in public using an SET. The Ayre, despite being zero feedback, has output impedance low enough that its able to act as a Voltage source on most speakers. Any time you mix the two technologies, you are liable for a coloration of some sort as a Voltage source is very different from a tube amp with no feedback! IMO/IME you'll have to do some adjustments to make that work. But if you talk to Pure Audio Project, it might be simpler than I'm making it out here.
Gentlemen, please...
We are better than this on so many levels. Please check your egos at the door, stop talking about and referring to other WBF members and please stick to the topic at hand.
If you want to talk about topology? There is another thread dedicated just for that. Direct your comments there. Not here.
The members that want to learn from those that currently use and own a SET amp within their system would like to discuss just that. Nothing else.
The two or three members that don't quite get this? (you know who you are) Please consider this a warning.
Tom
Remember Seinfeld and the Festivus Pole. Maybe we need a thread to air grievances and feats of strength.
I just posted a review of an SET amp on the general forum if anyone is interested in reading that rather than arguing?
Many if not most people who have SET amplifiers have arrived at that choice after experiencing solid state and other vacuum tube designs. Sure, SET have their constraints and drawbacks, but to get that immediacy along with other attributes is special. Well, since apparently SETs aren't great at bass, maybe I hit the jackpot because my PSET 2A3 amplifiers are driving 2 way stand-mount speakers.
Stand-mount (I don't like calling smaller speakers bookshelf) speakers also have their limitations regarding bass extension, but people still are drawn to them for the the way they can image and disappear. If there were a 2 way bookshelf speaker forum, there is no need to call out that those speakers can't do bass. Audiophiles acknowledge what they are giving up if choosing a small stand-mount speaker that may not extend reliably below 40-50 hz, just like SET owners are aware of constraints mostly due to limited power.
Although different, SET fans are making similar compromises to get the sound qualities which SET amplifiers can deliver. Perhaps some have efficient speakers that deliver good bass performance with their amps.
It is a shame that despite a lot of valuable knowledge and experience shared on this forum, much beyond what I could contribute, it seems that there are some killjoys whose focus isn't upon optimizing the performance of SETs and SET ownership experience. Let's get back to the joy of the SET experience.
