Shun Mook MC Reference Cartridge
So you moved things in my room without me knowing while I was in the meeting. I didnot hear that. No witness. I only heard what I heard on the second day and you said it.
Kind regards,
Tang
No you were there on the first. Actually the first and second Mook day I mentioned was in reality the second and the third day of my visit. You heard it and said something to the tune of all tweaks change the sound but then they keep that constant. You mentioned you could hear it go wider and clearer and more like concert but said that is what tripoint or cables would have done as well. But then you tonearm guy came and we took them off
Today was "the" day and the Shun Mook MC Reference arrived.
The
- Yamamoto HS-1AS Ebony wood headshell with soldered thick 6N copper headshell wire
and the
- Yamamoto HS-1A Ebony wood headshell with
- Ortofon LW 1000S pure silver headshell wire
were prepared, Yamamoto Titan headshell screws as well.
At first I installed the Shun Mook in the HS-1AS, as I mostly like copper wires.
The SME 3012 R (connected with the old SME tonearm cable , one side RCA, one side XLR to fit the Boulder 2008) is easy to set up, so I had the first music after just some minutes.
The Shun Mook response to VTA, VTF, and so on is direct an clear, so good to tune to a matching point to start listening (2+G and the back of the tonearm a little higher)
Recommeded load is 100ohm (8ohm DC), but I preferred 200ohm with the Boulder 2008.
The firs impression is as expected, very warm, very harmonic, very soft.
Listening to "Girl of Ipanema" is "erotic" , as it can be.
But listening to some power jazz with horns and trumpets the shun mook is in my set up a little bit too soft.
And I have to decide now, if I want to fintetune the Shun Mook, that it sound more according to my "standard"
The exchange of the headshells to Yamamoto HS-1A and Ortofon pure silver leads is done quickly, The result fits my taste much more. Metal Instruments do play now more natural.
This is now a tonal balance, which reminds me on a Koetsu Rosewood Signature , before it was even sweeter.
As the Yamamoto HS-1A is from ebony wood as well, I assumed, that this headshell is the best pairing partner.
remembering the Koetsu carts, I might try some other headshells as well.
The Shun Mook sonic finetuning is very sensible, even the torque of the screws is important.
So this cart will give me some finetuning fun during the German winter time :)
But the state of the Moment is is already good and and very much involving.
IMG_8706.jpgIMG_8705.jpgIMG_8701.JPGIMG_8703.jpgIMG_8704.jpgIMG_8696.jpgIMG_8697.jpgIMG_8698.jpgIMG_8700.jpgIMG_8695.jpg
Reactions: audioquattr
I assume you will be trying with the FR? Bill ying responds to queries and set up tricks if you ask him
The
and the
View attachment 45963View attachment 45964View attachment 45965View attachment 45966View attachment 45967View attachment 45968View attachment 45969View attachment 45970View attachment 45971View attachment 45972
Nice report! Looking forward how it will involve!
I am trying a wooden Grado Epoch at the moment, will report later.
A couple of hours later, the Shun Mook plays much more open.
I would say, that now the wooden Headshell and the wooden Cartridge body do have the same room temperature (they were stored before in rooms with 20 degrees celsius difference)
cannot see another reason , as that the resonance coupling of the two wooden parts do now work better.
The Shun Mook Cartridge was perfect with my Horn Speakers, but with my Wilson Audio Maxx 3 I prefer Carts with more energy in the upper regions, so I decided to sell the Shun Mook. You will find my No 107 listed in the WBF Classifieds section (under the Classifieds tab)
