Mike, do you mean cartridge weight or VTF? I think cartridge weight is compensated for by the arm's counterweight and basically the system is balanced until VTF is applied, independent of an individual cartridge's weight. Effective mass may be slightly more with heavier cartridges, but I think Anti-Skate or bias is more in response to the vertical tracking force being applied by the stylus onto the record.
there is a relationship between cartridge weight, cartridge suspension characteristics, and anti-skating and azimuth adjustments. the weights on the pivot arm are primarily related to azimuth, and the weight on the string is primarily for anti-skate, but they are interrelated, as is the tightness or looseness of the bridge clamp.
so it's all a system and done by trial and error. a tuneing sort of thing. i'm pretty good at it, jazdoc is the master. every time he comes over, he futzes a little and it gets a bit better.
the Tosca is child's play in comparison.
