Sme 3012 R
I know this old arm is good but I don’t know why David,Rockitman,Tang,Ron,Mike
Use or will use having top tonearm like Sat,EliteAxiom,Black Beauty,Durand
Why 3012 is so special?
I never had and I don’t understand
Only to know for my curiosity
Regards
Gian
I do have a 3012 question: Is it possible to lower the armrest/cueing collar? I prefer it if the arm doesn't travel as far to cue up and down. I've undone the set screw but that only seems to allow it to move horizontally, not vertically.
Yes, there’s another adjustment tube at the base of the arm. Loosen it and then rotate the armrest clockwise to lower the cueing mechanism to where you want.
david
Reactions: Fishfood
you can rotate the whole cueing assembly to move it up and down.
Reactions: Fishfood
I had this situation when my 3012r came back from SME after service.
I contacted Brian Laker who remembers building my arm as the original owner had specified a very high grade internal wiring and bearing.
You have to hold the base and spin the whole are round, not sure which way for up or down. Best to speak to service dept.
Reactions: bonzo75
