I would be interested to know how this compares with a refurbished B77 or PR-99 from a specialist such as Nagravox, wired to an external PB head preamp or using an upgraded PB card from Audvance. The cost of the ATR10 is substantially higher.So back to Sonorus ATR10 MkII ... I have one on order and it should be here somewhere around the end of the year. Looking forward to getting this in my system after hearing it at the dealer. Was an enlightening experience for me as that was the first time I had really listened to a good R2R and comparing to a really high dollar digital front end was really no comparison at all with the same albums. I'll post my impressions once it arrives and I have some time with it.
George
I certainly can’t speak to those other solutions as I didn’t audition those … I can only imagine though that the ATR10 would have some potential advantage in that the higher end electronics being internal are connected directly to the playback head and not as an add on solution. That said the ATR-10 is an amazing piece of playback tech and I certainly can’t wait to get it in.I would be interested to know how this compares with a refurbished B77 or PR-99 from a specialist such as Nagravox, wired to an external PB head preamp or using an upgraded PB card from Audvance. The cost of the ATR10 is substantially higher.
How do you like the PR99 ? Have you compared it to other machines ? If you have not upgraded the electronics, you should investigate this: https://audvance.com/PR99.html Not expensive and worth a try.I am also curious about this. Soren Wittrup rebuilt my PR99 and I have tape head out so a tape pre might be interesting down the road...
Any update on your experience with the ATR10 would be appreciated. I saw this at AXPONA and very much enjoyed listening to it. There are not many reviews available.I certainly can’t speak to those other solutions as I didn’t audition those … I can only imagine though that the ATR10 would have some potential advantage in that the higher end electronics being internal are connected directly to the playback head and not as an add on solution. That said the ATR-10 is an amazing piece of playback tech and I certainly can’t wait to get it in.
Going back to 35mm magnetic film, I have now collected 30 Everest classical titles on 4-track tapes. I would say I have pretty much all of the classical titles worth having on that label. These tapes are uniformly of very high quality. Everest was the first record company to record on 35mm magnetic film. After they closed shop, Robert Fine bought the equipment and used it to make some recordings for Mercury and Command. These Everest tapes must be the best kept secret in the audiophile world !3 track 35mm magnetic head - horribly worn from lots of use but look at the size of those tracks!
This looked really intriguing at Axpona last month ... would you pleaseSo back to Sonorus ATR10 MkII ... I have one on order and it should be here somewhere around the end of the year. Looking forward to getting this in my system after hearing it at the dealer. Was an enlightening experience for me as that was the first time I had really listened to a good R2R and comparing to a really high dollar digital front end was really no comparison at all with the same albums. I'll post my impressions once it arrives and I have some time with it.
George
So I have sold my entire vinyl setup and am now only digital and R2R. My digital setup is the Esoteric D1Xse Grandioso Dacs using an Esoteric Transport and Aurender W20SE for file playback. The vinyl setup I had was a VPI Avenger with transfiguration Proteus cart and the VTL phono pre. For my part I’ll say that the Sonorus ATR10mkII is sonically superior to either of those other two setups .. easily. It’s not something you have to really do critical listening to hear the difference.(like when I was trying to decide on which DAC I liked the best). The two most striking things to me are 1) the overall beautiful tonality on every tape I listen to 2) The absolutely incredible soundstage size all the way around … height, width and depth. I’ve never heard anything like it. For me I get totally immersed in the music and am lost. So far these are all tapes that I’ve sourced from Sonorus as well. So compared to the vinyl setup I had … when I had great vinyl the vinyl was still clearly better than the digital front end and the tonal richness was similar in the vinyl and the R2R although the R2R was better here by a small margin. On soundstage size … the ATR10mkII is the winner here by a long shot. I sold my vinyl setup because I was having a very difficult time sourcing new vinyl that was super quiet even from some of the audiophile sources. With the Sonorus ATR10MkII I don’t miss the vinyl at all and my Estoeric Grandioso stack doesn’t get nearly as much use as I thought it would. Hope that helps and good luck!This looked really intriguing at Axpona last month ... would you please
give some sonic impressions? Specifically compared to your vinyl?
Fascinating! What percentage would you guess you listen to digital vs R2R?So I have sold my entire vinyl setup and am now only digital and R2R. My digital setup is the Esoteric D1Xse Grandioso Dacs using an Esoteric Transport and Aurender W20SE for file playback. The vinyl setup I had was a VPI Avenger with transfiguration Proteus cart and the VTL phono pre. For my part I’ll say that the Sonorus ATR10mkII is sonically superior to either of those other two setups .. easily. It’s not something you have to really do critical listening to hear the difference.(like when I was trying to decide on which DAC I liked the best). The two most striking things to me are 1) the overall beautiful tonality on every tape I listen to 2) The absolutely incredible soundstage size all the way around … height, width and depth. I’ve never heard anything like it. For me I get totally immersed in the music and am lost. So far these are all tapes that I’ve sourced from Sonorus as well. So compared to the vinyl setup I had … when I had great vinyl the vinyl was still clearly better than the digital front end and the tonal richness was similar in the vinyl and the R2R although the R2R was better here by a small margin. On soundstage size … the ATR10mkII is the winner here by a long shot. I sold my vinyl setup because I was having a very difficult time sourcing new vinyl that was super quiet even from some of the audiophile sources. With the Sonorus ATR10MkII I don’t miss the vinyl at all and my Estoeric Grandioso stack doesn’t get nearly as much use as I thought it would. Hope that helps and good luck!
I still listen to digital more as I only have about 35 tapes so far. Probably 70/30 but I'm going to work on adding more tapes this fall when I should have a bit more time to listen again and a bit more money as I'm going to pick up my new Porsche Macan GTS this weekend!Fascinating! What percentage would you guess you listen to digital vs R2R?
Master tapes or 1:1 copies are quite limited in availability, although if you know the right people, many of the great recordings from the 1950s to the 1970s can be found. That is why I got into 4-track tapes, in order to fill the gaps in my tape library. The quality of some commercial tapes can approach that of master tape copies, and is clearly superior to vinyl. These tapes retain the naturalness and flow of the best tape recordings, and can give that elusive illusion of a live performance. For example, I found an ultra rare set of Readers Digest Beethoven symphonies, conducted by Rene Leibowitz. These are Kenneth Wilkinson recordings made in Kingsway Hall, and the quality of the tapes is tip top. Produced by RCA Special Products Division, i have yet to hear these works better recorded. I wonder which other recordings this division has released Another astounding label is Everest, which apparently developed their own production equipment for these tape releases. I think these present the best value currently available as far as physical playback media is concerned.Well... vinyl is not just a sound source, it is also a library of great performances, many of which are not available anywhere else.
I don't listen to vinyl as much any more, but in some cases that was the only place I was able to find the particular recording.
That is why many of us have thousands of records, that perfectly coexist with other recording media.
My audio dealer wasn't happy with me when I told him I was going to buy a complete Burmester Audio system ... just not one for the house!
