Hi guys,
I just realized that I really should have been considering the fact that this unit does have other use applications other than just a fixture on your high end audio rack. It does have a Mini PCI-E slot on the board. And in that slot you could always install a very fast dual band AC wifi card.
http://www.amazon.com/Bplus-7260-HM...TF8&qid=1452277138&sr=1-3&keywords=intel+7260
I have done it before and works great. However it does add noise. So where you would use it is in portable locations that you don't want to run wires to. It still sounds excellent, after all most of the mainstream several thousand dollar streamers have the same wifi cards built in them already. So at worst, it would just take the noise levels up to where they are at. It's super long range too as it's AC. Antenna is already built into the case and ready to go.
So just think, out in the backyard or something. You could stream Roon/Tidal, even upsample to DSD, wirelessly, and control with the iPad. Or anywhere for that matter. You will have the full music collection off your main server, as well as Tidal, wherever you plunk it down. Takes a second to switch zones on the Roon app. And theres no limit to the amount of zones. Also 1 image is good for as many zones as you want. You don't need to buy another copy for each unit. It would seem crazy if you were paying $1-$5K per unit, and getting 1 for each room. But when they are this cheap, you can put one in every room for less than the price of most commercial unit's of equal quality.
So something to consider anyways. No need for all the fancy upgrades either if it's just out by the campfire in the back yard or something. Around the hot tub.
