Hello,
This is my first post here.... I just joined the forum.
I purchased my 1.7i almost a year ago. Since then I've played with DACs and preamps... I'm afflicted with the dreaded Audiophile upgraditis bug...
Yesterday, I was playing around with subs setup in my home theater.... I have several NHT subs. One of the subs was an 'oddball'.... a 10" ... the others are 12".
So... I had an idea. I took it into my listening room and put it center between my Maggie's... it has speaker level inputs AND outputs. I ran 12TC from my Bryston 4b to the sub and then an additional pair from the outputs of the sub to the 1.7i's. The x-over set to 50hz .... after much listening.
This is friggin amazing!! I'm guessing it's got something to do with the Bryston really liking the load it's seeing.... THIS SOUNDS GREAT!!!
Image dead center... soundstage go's far beyond my walls of my 12' x 21' room. The Maggie's are singing like I've never heard them before! I didn't expect this...
Magnepan... make a sub!!! A real sub.... just try it... please.
BTW... I've used subs with my Maggies before using line level inputs and running the Maggies full range... just sounded like you would expect... like a sub following three steps behind.
This is musical... and the Maggies opened up like never before... it's wonderful. I don't have other amps to switch out, so I can't test my 'load' theory....
But... this sounds good...
I know... take the pill...
