which titles?Mine arrived today. They are outstanding. No buts, ifs, or howevers. Just superb sounding. Insanely quiet. Clarity galore. Strong and textured bass. Balanced tone. All the boxes checked …
No, because the tape copy you buy is a copy of a copy of a copy. Each copy adds a few dB of noise, among other issues. The Supersense are directly off the master. I have several, they all sound great (but the live direct cut Guy Chambers did not).Isn't it easier to just make tape copies as Chad and others are doing ? I doubt a lacquer would sound better than a 1:1 tape copy. And copying tape is a much more reliable process than cutting lacquer. I guess Universal is more likely to license their recordings for lacquer, since making tape copies risk piracy. On the other hand, if someone wants to make copies, they can already use the digital files that are easily available.
Unfortunately supersense is cut from a copy too. Probably a copy of a copy of a copy of the master tape but I’m glad to hear that it sounds great.The Supersense are directly off the master.
No, that’s not correct. Not sure what made you think so but it’s entirely incorrect:Unfortunately supersense is a copy too. Probably a copy of a copy of a copy of the master tape but I’m glad to hear that it sounds great.
Which tape copies are you referring to ? For example, 2XHD and Audionautes both received the session tapes for Jazz at the Pawnshop for their tape releases. Opus 3 also uses their session tapes for their limited series of tape copies. For Analogue productions, a 1/2" production master is made from the original edited work parts and tapes are copied from this master. I very much doubt Mastersense would be allowed to cut each individual lacquer with the ancient original session masters. At best, it would be a production master, copied from the session masters or more likely a safety master. While tape copies are often made with 8 or more recorders in parallel, the lacquers are cut one at a time. The master tapes won't be able to survive playing back 50 times to cut 50 lacquers.No, because the tape copy you buy is a copy of a copy of a copy. Each copy adds a few dB of noise, among other issues. The Supersense are directly off the master. I have several, they all sound great (but the live direct cut Guy Chambers did not).
The lacquers are fragile though.
The concern is not wear from playback its damage from handling. You have to be VERY careful - do not even brush them - just air blower to get the dust off. I nicked one side of Gilberto/Getz with the record weight and the last track now skips… but man does it sound great.
Supersense is cut directly off the first copy of the master tape. Deutsch Grammophon made an investment in Supersense, which is probably how they get access to the tapes.Which tape copies are you referring to ? For example, 2XHD and Audionautes both received the session tapes for Jazz at the Pawnshop for their tape releases. Opus 3 also uses their session tapes for their limited series of tape copies. For Analogue productions, a 1/2" production master is made from the original edited work parts and tapes are copied from this master. I very much doubt Mastersense would be allowed to cut each individual lacquer with the ancient original session masters. At best, it would be a production master, copied from the session masters or more likely a safety master. While tape copies are often made with 8 or more recorders in parallel, the lacquers are cut one at a time. The master tapes won't be able to survive playing back 50 times to cut 50 lacquers.
Analogue productions have, I think ,at least 8 ATR102 machines running in parallel, so they can make 8 copies in one go. I think they are allowed to make one production master with 1/2" tape from the master sent by the record label. Even if limited to 100 runs, they can make 800 copies, but I don't think any of the titles has sold that many copies. In any case, with the ATR102 being one of the machines with the best mechanics, they can probably do 200 runs without problem. I don't know what will happen when the quality of the production master starts to deteriorate. I suspect they will simply withdraw the title from sale. Foné and Opus 3 will only make 50 copies (one by one on demand) for each title, since these tapes are copied directly from the session masters. Audionautes was allowed to make one production master and one safety master from the Proprius session tapes, but Fabio has not indicated how many copies he will sell, since the tapes are also copied one by one. I believe in fact that the licensing deal with Proprius places a limit on how many copies he can do.Supersense is cut directly off the first copy of the master tape. Deutsch Grammophon made an investment in Supersense, which is probably how they get access to the tapes.
The copy is played 100 times to make 100 lacquers.
The albums on R2R are not limited to 100 units, as far as I can tell, and 100 plays is - from what I have read - the limit before SQ degrades on a tape. So you are getting a copy that is multiple copies away from the master. Sonic Flare talked about this on his YouTube channel. Michael Fremer talked about this on Tracking Angle (John Coltrane UHQR review comments).
That said, it would be interesting to compare sound quality between a Supersense album on a really high-end TT, with a tape of the same album that is purchased (I.e., not a one-off tape that someone owns, but a store-bought album).
I am only using a CTC Garrard 301 with an Alfred Bokrand 12" tonearm and Ikeda TT9 cartridge. That vs. a Nagra T Audio tape machine might not seem fair, but the Nagra did cost less when I bought itInteresting insights @adrianywu. I didn’t think any label was allowed to play the original masters 50x, but I assume your info is correct.
What record player are you using to compare?
I can tell you that my Nagra Reference TT/cartridge/HD Phono has no noticeable noise (and my horns will amplify the slightest noise), with most well pressed albums. And dynamics and frequency range, are incredible. Orchestral? I have grown up attending my father’s concerts (he is a professional violist) and I compare to that reference. Last year I was at John William’s 90th Birthday concert at Lincoln Center, seated in the 3rd row, center. Closing my eyes while playing the Raiders’ March from the DG Berlin concert took me right there - it was incredible.
Turntable innovation has come a lot further than tape machine innovation in the last 2-3 decades, so it would be interesting to compare a truly world class TT playback system with a R2R.
Tape is EQ’ed as well, for the same reasons that EQ is applied to vinyl.
And tape can only be played back ~50 times before degradation occurs (which is why these masters are not played more for the albums you mentioned).
I have not yet heard of a review between say a Nagra/SAT/TechDas AF0/1 with a world class phono stage and a top level R2R, with a tape that anyone can buy (I.e., not a one off master copy).
Bass frequencies under 100Hz also need to be summed to mono when cutting lacquer.
As @Solypsa noted summing bass to mono is not a necessity. On some occasions summing under 120Hz or 90Hz can be beneficial for cutting but I have many records with bass panned to one channel.Bass frequencies under 100Hz also need to be summed to mono when cutting lacquer.
What is your experience comparing master tapes to the Mastersense lacquers ? Which tape machines do you use and which tapes do you have ? I will be interested in getting one of the lacquers if they can equal or even be better than a tape copy.I can certainly appreciate cost as an important criterion, but for this topic I’m just interested in what sounds best. I’m not bashing the Gerrard 301 and Ikeda TT9, but you may be shocked if you hear a good album on a more exotic TT.
Tape has its own set of drawbacks, which I think you gloss over.
A record will not degrade, on a well setup TT. Fremer, and others have discussed this in the past. You can play a record back thousands of times with no deterioration. It will also last 100+ years with no degradation. Not so for a tape. Supersense lacquers will degrade of course, but there was a review where they were played back 100 times with no measurable degradation (that’s probably the limit, though).
If you are trying to copy and distribute a master tape, I believe vinyl is the best way to do it. Each copy of a tape degrades the sound (see Sonic Flare‘s YouTube discussion on this). No album on tape is copied from the master, simply because they cannot run the master tape dozens of times.I checked out Opus 3 and they certainly do not say they use the Master tape to make copies for the tapes they sell! They say “From the original albums” - that’s what they all say. Of course it’s from the original, but they don’t tell you how many copies are between the original and the tape you can buy.
With vinyl, the lacquer is often cut right from the master, or just 1 copy from the master.
It’s actually a simple mechanical process that - if you think about it - more closely matches the movement of the microphone diaphragm that actually created the recorded signal.
Not to say the plating and molding processes are perfect - far from it — but I think they preserve the original recording better than a tape (that you can buy). If you have a tape that’s a direct copy off the master, different story; but those are not purchasable by the public.
Fremer, in his Tracking Angle review of Coltrane’s Love Supreme (45 rpm UHRQ) recently made the same argument: that on his OMA K3, he bets it will sound better than the Analog Productions Tape. But it would be interestIng if he actually tried it.
It’s under 120Hz. Yes, subwoofers are located away from the speakers in the room cause ear can not detect the direction under 120Hz but that doesn’t mean there won’t be any problem. Unlike direction, ear can easily detect phase differences under 120Hz. That’s the problem with subwoofer placement and using single subwoofer. As a result you can not place subwoofer anywhere in the room. IMHO subwoofers should never be used in a hi-end system.It’s been well documented that bass direction under 100Hz cannot be determined by the ear/brain.
This is why subwoofers are placed anywhere in a room, where EQ is best, not where they produce a ‘stereo’ sound/imaging.
Are you comparing Supersense Mastercuts or vinyl to tape? The above article you referred to was about vinyl vs R2R tape. Things look like a little bit mixed here. Which is it that you’re comparing here, vinyl vs tape or supersense vs tape?Links for previous points:
2023-08-23 12:17:16 PM
Michael Fremer wrote:
I just had my A700 restored. It sounds great. However, consider that the UHQR record was cut directly from the second gen tape that sounds fantastic. The tape you buy is sourced from a copy of that tape, so you are listening to a copy of a copy of a copy of the original master tape. That's a considerable number of generations down compared to the source used to make the record. I have yet to hear any of these for sale tapes but hope to soon. My analog vinyl front end is state of the art, so it will be interesting to compare a UHQR to a tape....
Since we are here talking about “what’s best”, until I read, or hear, the same album on a top-tier TT and top-tier R2R, the evidence supports that vinyl sounds better. (I am not considering one-off tapes that are direct copies of the master, I am only considering commercially available albums.)
