Pondering between a new TAD M1000 power amp and a 8 years old used M2500 mk1.
I’ve read the M2500 is overall more expensive than the M1000 as it has much bigger transformers and it’s cut from a 90kg aluminium block, with the M1000 having updated internal components vs the M2500 mk1, and that the listenable difference is marginal.
At the same price, is an 8 years old M2500 mk1 much better than a new M1000?
the extra massive weight and aesthetics of the M2500 are cons to me.
Appreciate the advice.
