Good point! IIRC, one of the best systems I heard used galvanic (transformer) isolation of the supplies and opto-coupling of the digital lines into the DAC.
Surely you don't mean that?? In biological sciences, there are absolutely uncountable "middle positions". Even in physical sciences, in which I am not as expert, there are many "middle positions", even without delving into quantum physics. In behavioral sciences, such as psychoacoustics, I'm not sure there are any positions that are NOT "middle positions".
Not directly on topic, but try burning audio CD's at your burners maximum speed from FLAC, APE and WAV files. I'd be surprised if you didn't find the CD burned from WAV files not only to sound better, but to be the only one which extracts accurately (i.e., giving you bit-identical rips to the WAV files you started with.)
Surely, if you do not believe that CD transport quality affects the sound quality of a DAC, my questions and arguments have no meaning at all.
I still strongly suspect that a dedicated music server has a better potential for good sound than a general purpose computer, even one optimized for music playback.
It all depends whether you consider the world to either be made up of a series of completely independent black boxes, or at some level it all exists as a continuum. And your language indicates that you take a "digital" view of the first scenario: either elements, components of an audio system in this case, are truly behaving as lone entities; or they are defective, it's either one thing or the other. I, and others in the audio world, take the view that once you link these elements by some means, or they are in close proximity, that then at some level non intended interactions result, and in the case here of audio systems, audible differences will be heard.And I strongly suspect that in properly-functioning instance the audible differences are wholly imaginary.
It's amusing to see how far you guys (it's almost all guys) are willing to burrow down the rabbit hole.
..which, of course, makes no sense. One doesn't 'burn audio CDs' from FLAC files. They are of course expanded to .wav first. And it should make absolutely no audible difference unless your system is broken.
I certainly do mean it. I'm an academic biologist. Show me some positions which are 'middle' -- i.e., one in which the evidence is just as good on one side, as the other. Certainly the thing that the lay public considers 'controversial' in science -- evolution, anthropogenic climate effects, and, to bring it on home, audibility of most audiophile nostrums -- are not really controversial in science (including psychoacoustics).
As expected, Part III of this article claims that WAV > FLAC > WAV is not transparent.
I wish it was just that. But they go miles past that.As expected, Part III of this article claims that WAV > FLAC > WAV is not transparent.
Either their system is more transparent than mine, or their WAV > FLAC > WAV conversion is less transparent because I sure can't hear a difference no matter how many times I convert WAV > FLAC > WAV > FLAC > WAV. Heck, I can't even hear the difference between WAV and FLAC.
I certainly agree to this. Their system must be broken. That's the only way.
