That must mean I’m only half a man as I measure at 115vReal men have a voltmeter and we measure at 230 V
One of the reasons I use a Balanced Isolation transformer which accounts for load by using a tap with a couple of volts higher to account for voltage sag, that and the benefits of CMR.Only exceptionally or with poor quality / underpowered regenerators. Most of us do not have kilowatt Krell's!
People should get an AC voltmeter and measure the difference in their mains voltage when they switch a 5A load on and off. Many will be horrified with the result.
It all depends on the room and the speakers interaction with it. I used diffusion and absorption panels with good results to treat side reflections and behind the listening seat. Yet I try to avoid using treatments whenever possible as they can unbalance the overall sound, IME.Yup. Just yesterday I fixed the left hand first reflection point of my speakers, with ASC diffusion panels at the right distance and, finally, right height. Clear reduction in distortion which could not be achieved any other way, brilliant result (thanks, ASC!).
My speakers are about 2 feet from the side walls. Of course, when speakers are less close, then such side wall treatment may not be necessary.
There is too much dogma going around on this. I was happy, after some experimentation, to remove all of my remaining ASC TubeTraps recently upon ddk's great suggestion, which worked this time around since my acoustic situation has changed from what I had before. But then the proclamation by some that all professional acoustic treatment is bad is over the top. I am not dogmatic either way, I take whatever works. If it's removal of room treatment, great, if it is addition of room treatment when it delivers the result, great too!
And yes, my ASC window plugs and ceiling diffusers are indispensable as well. But again, that is room dependent. There is no quick and easy formula for any of this.
There is too much black and white in the discussion, like with analog vs digital or anything else. The world is not black and white, the world is gray -- full of nuance and situational shadings.
What specific type of ASC panel are you using at the first reflection point?
I see. IMHO we can't call them of diffusion panels - three reflector strips do not work as proper diffuser. As you say, they are an absorber with three strips for reflection.Tri-Panels, with three o-called reflector strips (for diffusion), hence the name.
They are not in their regular product catalog anymore, but look like cinema panels,
Cinema Panel - Acoustic Sciences Corporation
Designed For Home Theaters ...but useful in any application where appearance is of the utmost importance. Repeated requests from Architects inspired our R & D department to design a sound absorbing panel which met three goals: 1) bring sonic and visual calmness, 2) blend well into a home...www.acousticsciences.com
Yet the latter have only two reflector strips, if I remember correctly. I custom-ordered my ceiling diffusers with three reflector strips rather than the usual two as well. If I need more Tri-Panels, I can also custom order these. ASC are very flexible.
Correct. A broadband absorber with what amounts to a scatter plate in front of it in order to taper the amount of high frequency absorption.I see. IMHO we can't call them of diffusion panels - three reflector strips do not work as proper diffuser. As you say, they are an absorber with three strips for reflection.
Thanks. Tim, for finding this link in my youtube page. Duh? A lot of times these links don't exist in the youtube page and even when I see one I've never clicked on one. On the other hand, there's been a few times where I've gone out to youtube to search for comparable videos. But it's only been for 50's thru 70's recordings like Miles Davis, Dianna Ross, etc. And in those cases, I've always been more impressed with my recordings and sometimes by a wide margin than what I've found elsewhere. Not this time.It may be the lower notes on a trumpet I'm hearing. I saw that tuba on the cover photo and thought maybe. This link is on your youtube video notes where it says "Music in this video".
Except that the reflector strips are below a woven fabric, so the overall effect is probably more diffusion than reflection, certainly 'hard' reflection.
Here is info from the ASC website:
https://www.acousticsciences.com/products/sound-panel
"The Sound Panel provides absorption from 200Hz up through the entire treble range. Like other ASC products, a built-in reflector strip is used to maintain diffusive ambience."
That is a lot of information from RPG! I'll be looking at that for a while. The SoundPlank is basically a thin broadband absorber panel. The reflective strip has been added with feedback from audiophiles so that it doesn't overly absorb the treble. Since the strip is thin the sound diffracts around it's edges and gets scattered. The planks are designed also to be spaced apart so there is some reflection off the wall between the planks. Overall you get a partially absorptive, partially reflective and diffusive effect.Well, an acoustic diffusor is not a device that "is used maintain diffusive ambience". It is a lot more than that.
Unfortunately a proper diffusor needs considerable depth and distance to the source, something that is hard to get in most rooms. For a quick great presentation on room design evolution, sound treatment devices and acoustical distortion we can look at https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiiyNXQs4XvAhUD3IUKHRcDD7QQFjAAegQIARAD&url=https://www.rpgacoustic.com/documents/2016/09/media-room-design.pdf&usg=AOvVaw2bO45s1g3KjRWjSnCiCyBm
People have very different ideas on how to deal with primary reflections in stereo, so we can expect very different views on acoustic treatments.
Tim,That is a lot of information from RPG! I'll be looking at that for a while. The SoundPlank is basically a thin broadband absorber panel. The reflective strip has been added with feedback from audiophiles so that it doesn't overly absorb the treble. Since the strip is thin the sound diffracts around it's edges and gets scattered. The planks are designed also to be spaced apart so there is some reflection off the wall between the planks. Overall you get a partially absorptive, partially reflective and diffusive effect.
I agree this is a great exercise and I'm glad you posted these videos. Some say it's pointless to post a youtube video of a system playing but I would strongly disagree. Certain things can be revealed. I suppose I should try recording my system but I'm terrified of what I'll hear! I don't have a good stereo microphone right now so that's my excuse. No really, I should get a decent stereo mic. and do it. Could be very informative.Thanks. Tim, for finding this link in my youtube page. Duh? A lot of times these links don't exist in the youtube page and even when I see one I've never clicked on one. On the other hand, there's been a few times where I've gone out to youtube to search for comparable videos. But it's only been for 50's thru 70's recordings like Miles Davis, Dianna Ross, etc. And in those cases, I've always been more impressed with my recordings and sometimes by a wide margin than what I've found elsewhere. Not this time.
I love this little gem Miller's Dance and I was both excited and a bit disappointed to listen to the one you provided. Yes, you are correct about the very soft blat of a tuba at the 36 sec mark not to mentioin a handful of other softer nuanced blats of a tuba throughout that I'm unable hear on my own. The more pronounced tuba notes I do hear on my own recording but still not as distinct. I see in the picture there appears to be at least one barritone horn. I don't know much about instruments. But overall, my recording seems predominantly trumpet nuanced by a few other horns. On "yours", predominantly trumpet but with more pronounced and distinct accentuations of the other horns. Overall, "yours" has greater timbral accuracy, better note delineation, greater distinction between types of horns, more overall clarity, and I'm sure I'm overlooking a thing or two.
At first I thought of my recording being a counterfeit to "your" recording i.e. a recording of a recording, and found some initial relief with that, but late last night I listened on my system again and recorded it and when listening in-room I still did not hear these nuances I heard on "yours". BTW, that's a bit of a testament to the accuracy / fidelity of what the iPhone / Shure MV88 recording mic and what they do capture. Even so, it was exciting to hear and a bit disappointing.
Hearing these differences, a few thoughts raced thru my mind including but not limited to:
1 My equipment is rather inexpensive. At some point that rooster could come home to roost and this could be that time.
2. A few AC-related shortcomings.
3. To the best of my knowledge, my biggest known deficiency at this time is my VMPS RM-40 speakers, though quite musical, are not tightly coupled to the subflooring but rather are only resting on the carpet via their flat base. Designer Brian Cheney did not believe in coupling speakers so I've no reasonably easy means to do so in a sufficient way. Not to mention these little beasts weigh 240 lbs each. A while back I had designed a new base to allow for coupling to the floor but I've yet to have the apparatus machined. I'm a huge fan of tighly coupling everything I can get my hands on and with prior speakers I had received an arbitrary 8 - 13% overall improvement. Assuming 5% improvement is barely audible. It's possible that some of what I'm missing in my playback system might be found there, but I doubt all of is.
4. Maybe I need acoustic treatments? Nah.
The SoundPlanks provide absorption from about 200Hz on up. Agreed, a good sound diffuser should cover an appropriate bandwidth and will require reasonable distances to produce the intended effect. I'm not sure who gets to decide how well a device that causes sound to be scattered in a way less related to the angle of incidence has to work before it can be officially called a diffuser. I guess you have to decide what the operating frequency range needs to be and then how even the reflected response has to be over a specified range of angles. An ideal diffuser would reflect the exact same tonal balance of any sound that struck it off to a range of directions relative to the incident angle while maintaining perfect impulse response in each direction. A huge polycylindrical that was far enough away might pull it off. Fortunately, a good diffuser just has to work well enough to create a marked improvement in listening enjoyment.Tim,
Diffraction is not just scattering. It in order to create a diffusive ambience you need an appropriate pattern of scattering that must spread along the bandwidth. A few strips at the zone of at the first reflection point are not diffusing them. People can enjoy the effect, but it is not a diffusor. I think that the strips in the ASC panels are mostly a way of avoiding absorption in such zones.
In my room I have a few RPG Diffractal panels in the front wall - they are effective because the distance between speakers and wall is around 6 feet. What are you exactly the limits of what you are calling "broadband"?
Peter, indeed there is quite a contrast. I've no idea how the Telarc version was uploaded but my hunch is the track is a direct upload excluding any DAC processing or anything else potentially corrupting it. It would be nice to get the exact file size of their uploaded file size minus any video bytes I'm sure that's not possible. If it's the same file as my own, my guess is that version is the "holy grail" version, minus any loss primarily at our earbuds / headphones. Perhaps another testament to the value of some earbuds, headphones, videos in general, etc? FWIW, I only use Apple's wired earbuds.Thank you for posting these two videos side by side. That's quite a contrast, but there are so many variables that might account for the differences. The latter sounds damped as though the energy and information is not getting through to the listening/recording location. How is the first recording made? Is it simply the output of the DAC being recorded without the rest of a system/room to interfere? Is it the same recording?
As this is a thread about room treatment, I would love to hear some comparison videos of the same system in the same room with and without various treatments. Surely the differences would be picked up on the iPhone device.
(...) I'm not sure who gets to decide how well a device that causes sound to be scattered in a way less related to the angle of incidence has to work before it can be officially called a diffuser. (...)
Indeed, it was a good exercise and I appreciate your bringing this to my attention. High-end audio is never a destination but a journey as we can always strive toward better counterfeiting the original but never equaling it. Surprisingly I don't find my highly-rated Shure MV88 ($150) stereo condenser mic built for the iPhone to really be all that much better a mic than my iPhone's built-in mic, except that it's stereo and it provides greater consistency.I agree this is a great exercise and I'm glad you posted these videos. Some say it's pointless to post a youtube video of a system playing but I would strongly disagree. Certain things can be revealed. I suppose I should try recording my system but I'm terrified of what I'll hear! I don't have a good stereo microphone right now so that's my excuse. No really, I should get a decent stereo mic. and do it. Could be very informative.
Just because I appreciate your time and efforts and ears, does not imply I'm going to agree with you on everything.I have recorded my system playing a test track we use called the MATT.
It's basically a sweep through the bass and lower midrange but it's in quick tone bursts instead of continuous. You can hear each burst clearly on headphones but almost never do all the bursts come through clearly when listening to speakers in a typical room. If you add some bass absorption it can get a lot better.Online MATT Test | The Listening Test
Art Noxon comes back to AudioCheck with more information about all the things we can do with the MATT test in the context of a listening test.</em>www.audiocheck.net
I don't doubt that acoustic treatments can seemingly improve a playback presentation. However, if the playback system itself generates shortcomings (inaudible or corrupted music info) I just can't see the logic where acoustic treatments of any sort can restore any of that music info lost or corrupted. That would truly be a really neat trick because to the best of my knowlede such technology to restore / correct what's missing or corrupted has not been invented. Rather I can only envision acoustic treatments make an existing playback presentation more listenable. In which case acoustic treatments can only compensate for the effects (what we hear) and not actually address the cause at the playback system. IMO of course.Bass and lower midrange sound is almost never absorbed fast enough in residential listening environments to prevent some obscuring of details. The main problem is the parallel sidewalls and the parallel floor and ceiling at the front of the room. Upper bass and lower midrange energy emitted at various angles to the sides of the speaker hits the walls at a near perpendicular angles and loses very little energy on each bounce, so it can creep forward to the listener after bouncing back and forth a number of times and arrive at a variety of delayed times after the direct sound from the speaker, causing a smearing effect. This is why we recommend bass traps in the front corners of the room and against the walls directly off to the sides of the speakers. This is also why non parallel sidewalls and a sloping ceiling can be helpful. It's not so much about mode breakup as it is about moving the sound forward more quickly. The angled surfaces force everything forward and past the listener. Sound gets stuck in the back of the room instead, and that's not as much of an issue (unless you're sitting back there perhaps). It's lost some energy by then and tends to die back there rather than working its way back to the listener again.
No, I did not say it. Please read my post again and if possible correct your post. I said "my house mains is very stable ". It would be ridiculous questioning the use of the "clean mains "as being ambiguous and meaningless and using it immediately.
I will come to your long and interesting post later.
