You're listening to an S-D DAC there, what do you expect?If you don't love the sound of noise modulation, choose a NOS DAC.
Don't generalize my friend
If I were to do this, which one would I purchase? Is a NOS DAC commercially available? Brand/model names??
Analog has noise modulation too ya knowWhich DAC chip does that use ?
Come to think of it.......I have no idea! I would like to know. Can you tell by the posted specs? It's all I could find.
Theorical Resolution : 24 Bits > 192 KHz samples Rates
Resampling Rate : 384 Fs
D.A.C Architecture : Delta-Sigma Modulation
Power Bandwidth : 5 Hz to 24 KHz +/- 0,0015 dB
Channel Isolation : - 125 dB
Channel-to-channel phase error : N mesurable
Noise/Signal Ratio : - 130 dB
A weighted noise/signal Ratio : - 160 dB
Phase linearity : +/- 0.19°
Unbalanced Analog Output Voltage : 3,30 V
Balanced Analog Output Voltage : +/- 1,65 V
So why is it that digital - good digital at that - has so much trouble with this "inner detail"?
THanks, Jack...Hey Opus - looks like i am learning (from you)...i started skimming the specs and immediately thought (S-D chips)...and then i saw it listed in there.![]()
I suggest its because digital's noise modulation isn't widely, if at all, recognised. We really do need a measurement for it. What you describe subjectively about tonal shadings and dynamic accenting fits my understanding of noise modulation - most DACs and a good proportion of ADCs obscure this fine detail stuff by adding wideband noise which is correlated with the signal. But in the way that SNRs and THD+N and DR is currently measured, this doesn't appear, so those figures all look fine.
Opus...on the ADC noise bit...is there the equivalent risk of noise from other mastering jobs for vinyl/tape?
Presumably so...thus, unless you feel digital is more at risk for such mastering noise...(doubtful?)...then it appears that focusing on noise modulation in the D/A process is one key...which i think is what you have been saying in the past is your particular design focus...yes?
This is ridiculous!! -and utterly false.Technically, analog and digital are processess that convey information and actually are more the middle ground than one or the other:
tape theory (in analog tape decks loved by many) states that the iron oxides or whatever, take on a magnetic alignement, and as such eash particle becomes orintated one way or the other, and that is a digital process my dear fellows.
Definition of digital
adjective
1(of signals or data) expressed as series of the digits 0 and 1, typically represented by values of a physical quantity such as voltage or magnetic polarization. Often contrasted with analogue.
When high end audio is designed, and expecially high revealing systems, these kinds of things are known to better reduce things such as noise and distortion, that is, if one is inclined to drive all imperfections to zero or the quantum level!
I'm not saying that today's commonly used digital storage formats are the same as analog, but those of the immediate and easily foreseeable future are "analagous". 128x or even 256x DSD and 32/192 PCM and/or 32/384 DXD have data flow rates similar to if not greater than analog tape's data flow rate, because like it or not both analog tape and digitally stored music involve discrete "particles" which store data.
Even our hearing is "digital" in the sense that the hair cells in our ears only respond at specific levels, not at an infinite number of non-discrete levels. The auditory nerve and subsequently the auditory processing centers of our brains then convert those discrete signals into what we perceive as a smooth analog waveform.
