Dave, what about a video of the extraction, with some system tunes going on in the background
Dave, what about a video of the extraction, with some system tunes going on in the background![]()
Nice! Love a good extraction… it can be strangely quite mesmerising.I happen to have one! It's with my Strega and K5 grinder, from about 6 years ago. Taken on a LG phone from the era, the audio system is pretty obviously not in the same room, but I'll add that disclaimer. Unfortunately I can't make any excuses for the music, Pretty Lights is a local band that played live a lot at the time. He's really talented, but the music is really best live on a huge pa system.
A friend of mine who got an Espresso Forge also feels it produces similar results to his main machines, Londinium and Decent, so he got a Streitman, which is a manual lever with an open boiler and custom, slightly smaller diameter portafilter. I am starting to think that may be my holy grail of espresso machines. Like a good audio system, it's not overly complicated, but also not so barebones it can't do everything well. Not megabucks, but far from cheap. It should last a lifetime. I was a little skeptical, but after getting to use one in person I think I'm sold on it.
I have gone to a neck down basket myself. But, I'm only using 12.7 grams. I had a 10 gram 58 from Decent. It just ran too fast. Would channel and spray. I had to close the grinder so much it would start to chatter.
I moved to a neck down basket that is a funnel. I get a lot less channeling and can open the grinder by about 2 hous on a clock.
Ultimately I would like a thinner basket. But I don't like the extra work in the video of loading the basket. My wife is not competent enough tg deal with it.
I wish Lelit sold a replacement grouo head that was a 49. I don't get why home machines are 58. Why do I want to push 18 grams or more of coffee. Even commercial. Why 58?
I do like the Streightman a lot. Really artisanal, beautifully built… lovely workflow. I could go there for sure.
I have had E-61 group machines for 25 years and really have enjoyed the ECM Technika profi that I’ve had for the last 4 years. The flow rate control that I fitted has given lots of involvement and fine control being able to ride the flow rate throughout the extraction.
I’d thought about a saturated group next or lever… going lever is the way I’d most like to take it now to just get that baseline of reliable texture and sweetness of a proper lever god shot. Then there is the engagement and kinaesthetic joy and the zen of lever extraction.
I’ve shortlisted for the New Year (maybe) and come down to a balance on spend and a mix of function and control. Currently thinking either the ACS Vostok or ACS Evo Leva or the Nurri Leva.
ACS Vostok
ACS Evo Leva
Nurri Leva
As inspirational as they are I ruled out (below) the new Kees Van Der Westen Spiritello and the La Marzocco Leva X not only on well beyond my spend $$$ but also typical operational maintenance as ongoing costs… as sexy as they are I do like ECM like reliability and am thinking twice whether I’d sacrifice that bulletproof approach to engineering to go to something more exotic.
KVDW Spiritello
La Marzocco Leva X
I had a few different machines when I started out very modestly then just the two ECM E-61 machines which have been better mid level machines and both performed really well over the last 25 years.
I’d definitely like the next one to be a destination rather than just a step forwards… have to admit there’s some fantastic new lever machines out there now… very tempting.
Grinder can make dust. All my baskets are VST. And a couple Decent. I will look at some neck down.
If you go to this extent one should try roasting. Its not that complicated. I've been roasting for over 2 decades. Once you start your ruined! I buy my beans from Burman Coffee Traders. I've purchased beans from all around the world. I was into Columbian for a long time but now solely Costa Rican. I roast around every 3 weeks on the back deck...
The Fresh Roast SR 800 with the extension tube is a nice roaster. More powerful than the 450. 6-8oz at a time, I typically do 3 batches per session. Drum roasters are also nice but I would suggest starting with one of the models I mentioned. You'll hear terms of the "first crack". When I first started I was focused on that. Eventually you can visually know what level of roast you like. You can see when the oils just start to release from the beans. This is a good rule of thumb. Then you go into a cooling mode. You don't want to burn the beans. I've over done several batches over the years. I get side-tracked and then remember I'm roasting! Mad dash! I typically do darker roasts. However for more complexity I'll blend Darker, Lighter, Medium. As mentioned I'm partial to the Costa Rican and mostly buy organic. You can get beans from Africa to Papua New Guinea and everywhere in between. Over 25 years of roasting and have never stopped! Once you master it, hard going back. I never did...Yeah, there's some new roasters that seem intriguing. Tell us more, do you have any recs?
A mate has had a mix of various manual direct and spring dippers over the years but I’ve only had brief limited exposure to the levers and not lived with them. I did research the YouTube’s on many of the direct manual lever options as well as spring dipper levers.Those are all beautiful machines, can't go wrong. If you haven't owned a manual lever I'd try one before investing in a spring lever, for me there's no going back. It's like a manual sports car vs dual clutch. Both have their charms. My friend who got the Strietman kept his Londinium for making milk drinks. The only thing I don't like about manual levers is the lack of steamer.
I don't buy into the high-$ machines unless you're running an espresso shop. A friend had a Slayer for a while... nice but massive overkill and wasn't as reliable as you'd hope for a >$10k machine.
We’ve had Bunn at home and really enjoyed it. If I stopped doing pour overs, that’s the route I would probably go.On the edge of ordering a Bunn with pure stainless internals and the holder for it.
It’s not for everyone. I did it for several years 20 years ago, but eventually (when I found a consistently good roastery), I just got tired of the mess and the stink.If you go to this extent one should try roasting. It’s not that complicated. I've been roasting for over 2 decades. Once you start your ruined! I buy my beans from Burman Coffee Traders. I've purchased beans from all around the world. I was into Columbian for a long time but now solely Costa Rican. I roast around every 3 weeks on the back deck...
