I have ordered a 9" 4 point, it will be here in 3 weeks. I am determined to make this cartridge sing
I have ordered a 9" 4 point, it will be here in 3 weeks. I am determined to make this cartridge sing![]()
The recommended tonearm effective mass range for colibri mss is 10gr to 16gr. The 4 point 11inch me and Tima has has 18gr effective mass so the resonance falls on about 7hz which is not ideal. The 9 inch is 13gr and the resonance falls onto about 8hz, close to 9hz (depending on the mounting hardware) which is ideal.
The phono pre I have is quite adjustable and is a surprisingly natural sounding pre. The values are fitting as well.
So, first I will look into those who do not match ideally, the tonearm and cartridge. If that is not enough, then I will send the cartridge back to VdH along with my notes and will wait for him to make further adjustments.
I already decided to get the Grail phono preamp so phono preamp will change anyway.
I had the Grail for a couple weeks in my system on a demo. If the character of the MSS is similar to that of the Grail, it's going to be a startlingly dynamic duo!
May I ask why haven’t you preferred to keep the Grail?
Hi, my master signature has just returned from VDH.at least from initial listening I can hear a perceptible reduction in the high frequency energy though it still show through in some recordings. Other than that, it continues to be the best cart I have used.I have tried the 9" 4 point and yes it worked better with the cartridge, but I did not like the 9" 4 point itself. Also there were some other problems that stayed even with the 9" arm, so the cartridge has to be reinspected and readjusted. So, I sent the cartridge back and mounted my standart length 4 point with vta tower back on.
I asked A.J. Van den Hul to match the cartridge to my standart 4 point arm. I will let you people know how it sounds when it is back. I am still determined to make this cartridge sing in my system![]()
Though it's not a 4-point thread, could you comment on the differences from the 11" and what you did not like with the 9" arm?
I very much like The Grail SB phono stage. I have it on loan since a week and tested it with different cartidges.
It is quiet flexible and the current MC input works great.
All MC's are sounding good/optimal without any adjustment (because of the current input). And it is very silent.
The Colibri MS is the best pairing with this phono from the carts i have. It still is very good (for sure for the money) on other MC's.
It has great dynamics and good sounstage. Bass is fast and has enough bloom and better layered. I prefer the bass to my Pass XS.
Higher mids and highs are better imo with Pass xs. Also soundstage is a bit better to me with the Pass.
Only the MM input is much less good imo than the Pass xs.
Even on tone the pairing Colibri MS with The Grail i like it better than my TM phono. Allthough the Mayer is much more transparent and not optimal for the Colibri.
I think overall for the price the VdH Grail is a very good phonostage.
Yes. Than the medium gain(64dB) will work and is best soundswise to me.Your colibri ms is 1.1mV too, right?
