Thanks!I think I have 300 ohm and the high setting, who adds some more dbs on the Nagra VPS.
Thanks shakti!I prefer 400ohm Impedance and 65 db gain with my 0,9v Master Signature and the Boulder 2008 Phonopre
It may be a while until it is setup as I am not staying at my house where the stereo is currently. I need to get the new place situated and the stereo moved there. May not happen until Dec. Also I need to find out when I get the AS stand for the AS2000 from David.How many cards Christian.
Tang
Hope you have a smooth transition to the new place. I am moving to a new place next month too.
Tang
Kodomo san,I asked for the Colibri Master Signature Koa Strad and my dealer returned to me saying they are not in Koa anymore. Here is the answer;
Colibri XGW Master Signature Stradivarius (0,7 mV): Product code = A03HR.
The term 'koa' referred to a specific type of wood. It is now changed to 'Pau Amarello'
This makes me wonder now, how it would effect the sound!
Kodomo san,
Another thing you need to be aware of is this Master Sig is less forgiving on statics, click-n-pop's than other carts I owned. It is a very very sensitive cart. If I touched any part of my tonearm, I could hear the sound comes out from my speakers. Maybe this is why it is so darn lively and energetic. Make sure you clean your records well.
Tang
Tango, what you observed could well have to do with the much higher output from this cartridge than the others on your rig. The new Van Den Hul Colibri’s have more than enough gain...do you compensate for the differences at your preamp...and of course for the varying loading requirements that each cartridge requires?
Tango, I am with you, I too much prefer higher gain output cartridges, although that style is decidedly out of fashion right now.Dea
Dear Davey,
My Master Sig is rated 0.5mV which is pretty much the same as my Opus1. I prefer higher gain output carts. My preamp is already adjusted to the lowest possible setting. The loading I did by ears. When I lowered down the loading from my optimal point I lost that last bit of livelyness.
Kind regards,
Tang
