Amir maybe the SAHSA was not much of a load. Class is hot at idle.
Did you happen to talk to Dan about future products? Will he stick to amps, or will he go for front ends, like CD or SACD?
Also, did you happen to look at the rear of the amps? Did it have CAST, or is that a proprietary to Krell alone?
Cheers!
IMO the KPS25SC belongs in the Smithstonian as it is a remarkable work of art.
I sold mine for more than what I paid for it new. I'm kicking myself that I sold it
did you get to hear the 600e?
So what doesn't your solution do that has you searching for a new dance partner?
Holly mother of mercie Dallas.Do yourself a favour and give the Krell 600's a go!!
I can be an ass when it comes to money and power but ..WOW....130w/ch at $45,000 is crazy & 2KV worth of transformer(a Bryston 14bsst has that)..I went to Sterophlap and see Mickey ""The Mouth"" Freemer was flapping his usual **** to sell these high priced amps.
The measurements was a little lacking(by alot) with 130w at 8ohms and only reached 260w when one channel was used..
***THATS ENOUGH STEREOPHILE***-How is it you guys can measure a Krell FPB 600 to 945w/ch at 8 and 1850w/ch at 4ohms but when it comes to these ultra expensive ripoffs,YOUR wall juice somehow cant cope with 260w/ch????Cmon John Ak..get it right would you and stop with the voltage excuse??****
Dallas,you owe it to yourself to fill your room with real power.My room is near your size and a FPB 600 will fill it all the way up.Yes sir,it will find the limit of most monster speakers instead of the speakers finding the limit of the amp.And the monoblocks will do it. The 710 THD was a wild number at .00000000000000002 but hey!!
good luck
Hi JimI think you are getting caught up in the Watts war far too much. All amps are not created like your FBP 600. There are amps available with low rating that will drive difficult loads much easier than some well know products with crazy ratings. The MBL amps rated at around 440wpc drive 111f's and 101e's much easier than some 600 and 1200 watters. My Momentum's at 300wpc handled the pair of 11f's I owned much better than the McIntosh 1.2k's they replaced. Now the just laugh at the Alexandria's.
I have heard a pair of Accuphase A-65's tame Focal Utopia speakers better than some bigger amps.
Jim
