The Gospel according to Andrew Lloyd Webber
The sonics are excellent. For instance, on side 3, first cut, "The Last Supper", near the end, the twelve disciples leave the table and exit to the right singing in unison. Then they turn, moving further back on stage and loop around to the far left, still singing. It is an incredible spacial effect which is slightly more pronounced and clear in the gatefold and I don't even remember ever hearing it on the US Brown cover version, but I would have to check to make sure as my system has improved since I listened to that version.
Al, do you hear this on your CD?
Peter, I'll listen for that tomorrow, when I fire up my system again (not tonight).
I also thought about your earlier comment about some of the chorus being difficult to understand.
I don't remember having made such a comment (?).
The Lloyd Webber and Time Rice compositions and shows are great.
I never saw Jesus Christ Superstar
I saw it in Ann Arbor, Michigan with a local group. Excellent, and an unforgettable experience.
O.k., I listened today. Yes, I hear that with great ease, it's very obvious. However, I don't think it's well done sonically. It's with lots of artificial reverb, and the reverb starts way too early, before the actual move to the back of the stage; that movement is indeed a pronounced effect, however.
I have a few Stockhausen CDs where that effect of performers leaving the stage is done much more naturally and convincingly. The movement on these CDs usually is also even further back than on the 'Superstar' recording. I'll have you listen to some of these next time.
I thought you commented in your post #11 about the vocals being easy to understand, but not always. I just reread it and you wrote "essy" not "easy". My mistake.
And my mistake was that I used the term 'essy' instead of a more technical one. I hoped that it would be understood in the context of my mentioning de-essing of LP recordings (which is a standard technical term), but that mention came up only a few lines later in the posted text. My apologies.
