The magic of stereo
In my opinion, the foundational science of audio is solid. The problems come in when we have virtually infinite permutations of causative factors in playback. I'm sure we've all heard systems that are in seemingly terrible rooms (by dimensions, furnishings, etc.), yet sound fantastic. I'm also sure that we've heard systems that should sound great (on paper)that disappointed. Is it not reasonable to believe that science is continually progressive in its understanding of phenomena, where current dogma explains things to a point, then a new breakthrough allows far deeper understanding of the subject?
If we attempt to use fluid dynamics to explain quantum mechanics, we come up short. The science of fluid dynamics is pretty well understood, but just not really applicable to the other. The same is true IMO with audio reproduction in constantly-different rooms/systems. There just seems to be a missing piece to the puzzle. Rather than be a flat-earther, I'll use the current science to my avail as much as possible and realize that there may indeed exist some "breakthrough" concepts which will assist us in understanding much of what we currently label under "snake oil" and other "non-scientific" terms.
Lee
Can we close our eyes, and see (imagine, construct) moving pictures with colors?
Can we close our ears, and hear (inside our minds) a full Orchestra playing in front of us?
Are some people more able, adept to this feat than others?
I'm quite sure that some people are more adept at this than others. However, I don't think this translates over to two channel audio in that unless you have a great imagination you won't enjoy stereo. If you don't enjoy your stereo, it's because your stereo system has some issues that is causing it to behave Hoover-like.
When a recording engineer position his microphones for a Classical concert; how many does he usually use?
For best results a minimum for 3.
And what type? Cardioid? Omnidirectional? A combination of both?
Usually 2 Omnis plus another type which depends on the application/desired result.
Is that makes sense to use three on the soundstage (slightly above Left, Center, and Right), plus one more at the sweet spot in the audience to capture the ambiance of the Hall?
When using minimal mic techniques the main mikes are some seats into the audience space and flown. When close mic-ing is employed 3 mics won't cut it for full orchestra, too much bleeding and masking.
* Does a Hall full of people versus an empty one make a difference?
Yes it does. The human body absorbs energy and thus changes a hall's acoustic properties. People also make noise and raise the noise floor.
Hi Bob
I only have experience in mini concert recording (solo duet and trio), so many thing will effect to the recording quality, recorder not the only one, we did try, ribbon mic is better than cardioid for string music ,tube mic pre amp is better SS, silver mic cable is better than copper,499(ampex tape) better than 456 two mic direct to recorder better than more mic with mixer, if not in studio different room or with people will come up different sound, so a good recording has to try with so many things or by lucky
tony ma
Tim,
Not all. Even skipping our disagreement about electronics :eek: - no one can give you a set of measurements that will tell you how well your room images. Current acoustic science can not do it in small rooms.
No argument there, micro. What can be measured is the ability of the electronics to present an accurate representation to the speakers. All bets are pretty much off once you hit that point.
Tim
Mep, thanks! Those questions you answered were more of the philosophical/psychological type. But nonetheless they were deserving to be asked in the context of earlier discussion about the 'mind reconstruction' from the soundstage perspective, or the space of the recordings.
Jack, nice and clear answers! Straight to the point! I like! :)
Tony, fantastic overall and true realistic answer! So right! You got it; sometimes we hit that 'Magic' by pure coincidence, accident of circumstances, by experimenting, each and every time! And with different tools as well...
And that's where "The Magic of Stereo" starts first! It is not common, but few and between...
And the gear to reproduce it (the playback source, the preamplification, the amplification, and the two loudspeakers) are secondary in that real 'Magic' equation. ...As long as they are of 'reasonable' quality, and can pass that 'magic' unaltered.
Hi Guys
Personally I think you guys are making your job of analysis vastly more complicated than necessary.
I think you will get much farther by examining your hearing and not the “stereo image” on a recording.
For now forget the recording process entirely.
When a person stands in front of you and talks, you can identify the location aurally with your eyes closed.
Your ears Pinna response imposes an angle dependant comb filtering and eq to the pressure reaching your ear drums.
This looks awful in an “in ear” measurement BUT instead of hearing any of that as flaws and comb filtering, it is instead how you can determine height of the source.
When you wear headphones, you have neutralized that pinna response aspect of spatial detection and so with headphones, the image floats over your head or in your head.
If one takes a set of headphones and you feed the SAME signal to both sides, one produces the SAME mono phantom image one seeks with stereo.
This does not have to be a recording or have ANY processing, it is the identical nature of the R and L signal which make the phantom appear to be between them.
With loudspeakers, one can produce the same mono phantom image by feeding an identical signal to each speaker.
The more identical the signals reaching the R and L ear, the more “real” the phantom image can be.
With loudspeakers one also has some amount of IACT or inter aural cross talk, the sound which arrives from the Right speaker but wraps around to the Left ear and vise versa.
This corruption reduces the realism of the image because an actual source has none of that cross leakage.
A HUGE effect but hardly ever addressed is that essentially all loudspeakers radiate a complex pattern, this allows you hear where a single speaker is with your eyes closed but also hear how far away it is.
There are speakers that are VERY hard to identify the physical depth when only one is on, these tend to produce a much stronger stereo image when two are used.
When a speaker shouts its identity, the ear can easily hear the R and L speaker as the source which obviously competes with / defeats the desired phantom image.
It is possible to have a mono phantom image so compelling that people would rather believe it is a center channel speaker than the program material.
I forget who, but someone here had posted a picture of a small full range driver on a large baffle. This is one kind of speaker that would produce a “simple” radiation pattern and so likely to be hard to localize in depth and then produce a strong stereo image.
Keep in mind, you are trying to reduce all of the extra signals as much as possible, this is like a noise problem.
For example, in a room, normal loudspeakers image much more poorly than they can outdoors (by that I mean the image that can be created between the two sources).
The reason for that is in a room, there are many delayed reflections which all sound like the original signal but compete with the direct signal which is the one that creates the image.
Another problem is that loudspeakers spread out signals in time. Feed an broad band impulse to a normal multiway loudspeaker and one finds that instead of the entire spectrum being reproduced at one instant, it emerges normally with the highs first and lows last. Even examining an individual driver like a woofer with time delay spectrometry, one finds that even the lone driver produces the hf end first and the lf end last.
Obviously, any distortion, be it in time, harmonic, amplitude variations, any and all signals which arrive after the direct path and so on, corrupt the signal, these things allow your ears to determine this is not real, or that really sounds like Diana Krull floating in front of me.
Now, how one captures or re-creates that same real seeming image is an entirely separate can of worms (I think). There are ways to capture a live image, but none do what I am looking to do, the object here is to extend this into a 360 degree image with “over head” image as well.
A couple weeks ago I posted a link to a recording I made using a microphone invention I am working on. I believe I have found something new and useful but it is still a work in progress, try this link with headphones, keep in mind this the “forward” facing portion of the stereo image.
Also, like the last one I posted, I have to apologize for the program material, not exactly music but something I am very familiar with and so a valuable reference (and possibly entertaining of you like trains). Fwiw, there is NO compression, NO spatial processing of any kind, this is the output from the detector. .
Like the approach with the loudspeakers, I tried to fix the acoustic problem at the origin instead of compensations, see what you think / hear.
http://www.danleysoundlabs.com/TrainStart.wav
Tom Danley
Danley Sound Labs
Tim
And an accurate representation is one that measures good? :confused:
This model of accuracy misses something.
An accurate representation is one that doesn't vary from the input.
Tim
Tom Danley
Danley Sound Labs
Sorry Tom but I see and hear nothing (from your link just above in your quote)! :( True!
* I do agree with your nice previous post of course (#140).
Tim
...And one that can be tracked accurately as well! :) ...If only a very slight misalignment occurs at the tracking from the stylus of the cartridge into the grooves of the album, or from the laser lens of the tray mechanism into the pits of the disc; all is off!
The playback source is the snow, the ice of the mountain descending and forming a moving glacier, sloping down, spreading, and eventually melting down into new rivers, and creating new lakes; or the iceberg splitting, cracking, falling, and melting into the ocean. - Bob
...And one that can be tracked accurately as well! ...If only a very slight misalignment occurs at the tracking from the stylus of the cartridge into the grooves of the album, or from the laser lens of the tray mechanism into the pits of the disc; all is off!
True of the stylus, not true of the CD player or computer player running error protection. But nevertheless, these errors are a part of what would be measured. Any inaccuracies in the source would be a part of the signal going in to the component being measured and would need to be present in the signal coming out for that component to be deemed "transparent," or accurate.
Tim
Hi L.O.T.R.EE
“Sorry Tom but I see and hear nothing (from your link just above in your quote)! True!”
Umm, must be a link / web thing, sorry.
If it’s a link transfer issue, I am not sure what to do.
The manual way;
Go to Danley sound labs.com , Navigate to the technical download page, scroll down to the very bottom and download the train starting up.
Best,
Tom
Tim
Hi Tim,
I totally disagree with you regarding the laser lens of a CD player or a DVD/Blu-ray player!
A misalignment of the laser lens will cause your player to completely mistrack; break into pixelization (picture), drops of sound (audio & video pauses), or simply not able to load a disc because it cannot read it any longer! And that is a fact as I got the proof right here at home! ...And from several players too! :)
This is a real problem with many players and from many brands (Denon, Panasonic, Pioneer, Yamaha, ...).
And after one year, you're out of luck as your warranty is over!
I must have about three dozens or more CD players, Universal DVD players and Blu-ray players, and SACD players; and I know very well the issues with most of them!
It is most annoying and frustrating as you CANNOT fix them yourself! And that makes it even more expensive to be into this hobby and wanting an accurate tracking device!
Nothing is forever, and even more so with source playback electronics!
Regards,
Bob
Hi L.O.T.R.EE
The manual way;
Best,
Tom
Hi Tom,
I tried three times by clicking directly on your your link, but each time I could not access it!
* I will now do as you just said here above, thanks! :)
P.S. Call me simply Bob please.
{The Lord Of The Rings Trilogy Extented Edition is simply a username that I chose because I simply luv this Fantasy Movie Trilogy.}
Hi Tim,
Regards,
Bob
Hi Tom,
I'm sorry, Bob, I think I misunderstood you. You said "inaccurately" and I thought you were referring to some kind of digital tracking error that would result in minor distortions, colorations, inaccuracies. If you're referring to gross errors in reading the disc, resulting in drop-outs, break up and the inability to load the disc at all, we don't disagree at all. Though I wouldn't call those inaccurate representations of the signal, I'd call them "broken system."
Tim
I'm sorry, Bob, I think I misunderstood you. You said "inaccurately" and I thought you were referring to some kind of digital tracking error that would minor distortions, colorations, inaccuracies. If you're referring to gross errors in reading the disc, resulting in drop-outs, break up and the inability to load the disc at all, we don't disagree at all. Though I wouldn't call those inaccurate representations of the signal, I'd call them "broken system."
Tim
My fault Tim; I wasn't clear enough! ...For me a "broken system" is also an "inaccurate" one! :D
Well I certainly can't disagree with that. The solution, for music anyway, is rip them all to a hard drive and stick the CD player in the attic.
Tim
Tim
Yup, I'm still a hard core physical type of guy! ...Way behind the latest technological advancements!
* My computer has ony 40 Gb of hard drive memory, and only a CD player in it!!! ...Absolutely true!
And I totally relate to the Turntable people, as I am still one myself! A CD player is for me a Tunetable; but with a lens instead of a stylus!
...Still mechanical though!
...And with over five thousands CDs and CD-Rs and SACDs, I need my turntables, my CD spinners!
Most of my investment over the years, since 1965 or so, went into the software, the actual physical properties.
....And by an amount that will raise the hairs on the back of your neck!
LPs, less, but still...
DVDs, a lot!
Blu-rays, quite a few!
