I have only lost one record to silicon spillage, regretfully the remastered version of ”Communiqué“ is not as good as the original.Good one!
Aren't silicon troughs just a pleasure! Really enhances the hobby, don't you think?![]()
LOL Tim !Only if you bring your phone into your listening room.
I do understand your situation is unique, where your phone is your listening room. ;->
Since you address psycho-acoustics, can you refer to a serious study that reports that digital distortions are subjectively different from distortions induced by electronics?
LP is lower distortion, wider bandwidth and lower noise. Rudy was right on one thing- if the recording sucks you can blame the engineer. Many LPs don't sound as good as the tape for some very good reasons (not the least of them being that a tape was used to make the LP so you're another generation away), but if you were to compare master tape to the master of the LP, you'd find the LP master to be better in every way.I do think tape if done right has the edge though (at least has the potential ).
No, but I can point to the simple fact that while digital does not have conventional distortions, it does do aliasing which is a pretty audible form of distortion. That's the brightness so many people hear (the ear converts all forms of distortion into tonality). (...)
(...) The way I look at all this is the simple fact that the LP is still here. You don't have to know anything about the tech, just the simple fact that the LP is still around (the period of least production was 1992-1993) and increasing in sales is evidence that for what ever reason the digital is supposed tp be better, its failed to supplant/eclipse the prior art.
And just maybe some actually prefer the sound of the vinyl master/medium, granted they probably don’t all have DCS Vivaldi setupsSurely. But since long aliasing is not an issue of proper digital. I understand people can debate the technical aspects of analog sound reproduction of the 80's , but I am interested in learning about the digital sound reproduction of the 2000's, not the early digital.
It seems to me that the stereo sound reproduction science fossilized since long. Almost no one has carried controlled listening tests in stereo since long - but the old myths, coming from good science developed at an age where distortions and noise were orders of magnitude higher than what is possible today, still want to rule.
Should we remember that the increase of LP sales is mostly due to LPs issued from digital carriers? Only a few facilities have true analog pressing, including a look ahead head for driving the cutter spacing. Most of them have a digital delay and a DSP system to control track width.
IMHO the vinyl revival is a interesting social phenomena, not an audiophile miracle. My non audiophile friends are buying ten times more common LPs than the audiophile friends.See https://www.theguardian.com/music/g...inyl-choice-record-store-day-2020-in-pictures . People buy an LP with the same satisfaction as if they were buying a very good bottle of wine - we love rituals!
And just maybe some actually prefer the sound of the vinyl master/medium, granted they probably don’t all have DCS Vivaldi setups![]()
The way I look at all this is the simple fact that the LP is still here. You don't have to know anything about the tech, just the simple fact that the LP is still around (the period of least production was 1992-1993) and increasing in sales is evidence that for what ever reason the digital is supposed tp be better, its failed to supplant/eclipse the prior art. When that sort of thing happens in any market, its a sign that the prior art was not inferior. An example of this might be side valve engines. All engines these days and for quite some time have been overhead valves. That's because they are better in every way so far as reliability and performance are concerned. Digital is obviously not there yet.
This statement is really problematic. Most facilities do have analog; they'd be crazy not to as they cannot predict how the next project will turn up. Regarding the preview head/look ahead for groove spacing, that has nothing at all to do with the signal path. We have an older 'manual' lathe but automated it using an Arduino and a simple program that records the musical peaks. We have to play the project for it first so that it can get all the peaks and then we simply start it and let it roll except for the band gaps that we do by hand. But otherwise the Arduino controls the cutter thread speed. This took all fo $150.00 to implement. It does not matter then whether the project is analog or digital at that point; at any rate any kind of preview system is entirely out of the audio path that the signal takes going to the cut.
And then use a digital delay line - ADC- memory -DAC to delay the signal to perform the reverse look ahead function - I can't consider this an AAA LP! It is why some people in forums say they only buy originals
Most were done for a local label called Nero's Neptune- not sure if they are still around as the owner retired recently. But we only master them, we don't press them.Ralph ,
Can you provide a list of pressings from your facility , I’m not familiar ...
In an AAA LP project they don't delay the signal- its how the cutter drive screw is driven, which is to say when something complex is coming up the preview head speeds up the cutter screws to make room for it. These are two very different things! We solved the problem by mapping the peaks and then simply synchronizing the cut.
This is a common myth.The lost of information during LP playback exist at the cartridge stylus tip when ridding the groove modulations because that tiny stylus tip can't pick-up all the information recorded in those LP grooves and not only that but at that micro level the stylus tip jumps between grooves modulations, very tiny and microscopic level jumps: this is that the stylus tip momentaneous lost direct contact with the vinyl surface.
i can listen to digital for hours without ever missing anything. i'm never feeling short
but the vinyl has much more magic now. it can soar to previously unattainable heights.
. . . a question that every one of us could make to our self: which my main target through my room/system set up?
I understand should be the MUSIC enjoyment but there are several MUSIC enjoy ment levels. Whinch yours and yours?
Mine is the MUSIC enjoyment by be nearest to the recording that puts me nearer to the LIVE MUSIC experiences.
We can't mimic live MUSIC what we can achieve could be to reproduce the nearest we can what the recording microphones pick-up . . .
