Fascinating. I had no idea.
That makes two of us--and I bet we're not alone...
Amazing. And I thought I got an A+ rating because I had no complaints. Apparently it was just my $450 per year that get from me.
This story notwithstanding, I will continue to pay. Most consumers don't know about this "fraud" and any low grade would have the potential to affect my business.
Hi All,
Apologies for being a latecomer to this latest thrilling instalment of the TUC saga. I've been following WBF ever since Amir linked it from another forum, and really appreciate the informed and rational debate. I didn't sign up until I saw this thread, and having participated in many of the TUC threads elsewhere, I hoped this one might follow a better course.
What usually happens with TUC discussion is that people don't like some of the following elements of the business model and the way it's promoted:
1. TUC won't disclose the modifications they perform to equipment, which makes people suspiscious of what they're getting for their money.
2. Promotion is to a large part based on the money-back guarantee and customer testimonials, which may come from unreliable, inexperienced or unattributable sources.
3. There are no objective, comparitive, measurements before and after modification, either by TUC or by independant testers.
4. Modified equipment is not loaned for review.
These issues come up over and over again, and though they've been chewed over many times, there never seems to be any resolution. Debators are usually happy customers and sceptical observers. The impasse is never bridged, though this thread seems to have closer than others. Amir in particular has asked all the good questions, yet still leaves the door open, which other sceptics don't.
What this thread hasn't addressed though, is this: a typical TUC customer owns some equipment which they are very familiar with, then sends it away for modification. A couple of weeks later it comes back, and often gets burnt-in for few more weeks. The owner then finds it sounds better than before, and leaves a positive testimonial on AVS or TUC site. What they don't do is compare stock and modified equipment side-by-side, and they certainly don't do it blind. And the objectivists go to town on that. The customer, who is usually a subjectivist, has little defence against this.
Regards, Nick
The gurantee is fourteen days!
I suppose one could evallaute a mail order bride in 14 days.
As for me, I'm still on my first marriage and the wife is from NJ. I'm currently doing 32 to life.
... With no chance of parole!
I hope I haven’t missed the party on this thread, but there were a few things I wanted to talk about. This is probably the easiest one. I’ve read several claims from both customers and from TUC that video quality is improved, and got curious. A customer called Dave / Zaks (?) said his Pioneer BDP had improved PQ after the modification. Like many people, I was sceptical about this, but Zaks was quite convincing. Before the mod, his Arcam player was better with DVDs, but afterwards, the Pioneer was better. I initially thought this must be down to the picture settings, but it turned out his TV didn’t have DVI or HDMI inputs, so he was using the component video outputs.Thanks. Now, help me understand this from one engineer to another.
HDMI carries digital video. The receiver locks to its clock and captures incoming digital samples. To the extent you are getting video and then outputting it on a fixed pixel display (all the display types we use today), there is no possible way to improve the fidelity of the source. Period. Clock and signal variations do not matter for video as long as you are getting the correct picture.
So while I can give you benefit of doubt for audio, I can't for video. If you were making the above claim for analog video that would be one thing. But not digital video over HDMI.
Your turn .
Do you have those measurements? Who measured it and with what equipment?The Upgrade Company has pioneered the application of specialized shielding technology in consumer video electronics. Through the application of ferrite shielding plates that mount on top of integrated circuit chips, digital video and audio are both dramatically improved on both measurements and in objective comparisons.
Which law? Patents? If so, do you have a reference to it?The use of ferrite shielding plates directly on the chips is one of our proprietary approaches and not legal for any other audio or video company or modifier to use. This has never been done in consumer electronics and is protected by U.S. Law.
If I change the size of the water pipe to your house, does it make the water taste better?The first thing clients notice on an upgraded prepro is how much the HDMI video improved.
It might do all that. Problem is, HDMI video capture is truly digital in nature at some point. Once you recovered the signal, it doesn't matter how much better it is than the minimal detection level. As an example, if I need 2 volts to detect a "1" and you give me 3 or 10 volts, the result is the same. To the extent the customer is getting the right picture and sound, no improvement you do in the signal path can improve the fidelity of HDMI connection. This will be the case even if there is an electrical improvement.The biggest source of noise and jitter in the digital domain is airborne radio frequency interference: all metallic traces, wiring and the internal traces inside the chipsets collect RFI right out of the air, dramatically reducing performance.
Thank you for spending time with us.We're loaded up with work so I do not have any more time to devote to this topic today, but I'll check back later. By the way, this "What's Best" ID is the only name associated with The Upgrade Company.
