Gary, does this mean that in space a computer server with something like the Lynx card and a solid state drive is required for high fidelity? Ground control to Major Tom, errrr.... Gary!Unfortunately, this is too true.... but many designers will not implement something that they think will not affect the sound if they don't measure for it. As an example of how minute vibrations can affect a piece of gear, try putting something like a DAC upside down and listen to it. Of course, do not do this to a CD transport or turntable.
Yes sir, to go further, if you take it to court after getting an ass whipping you started you're two times a wuss.
Let's say I hit on someone's wife or girlfriend and her husband gets ticked off and instead of me backing off we had fisticuffs. Unless I was down and he continued to beat me or he used some sort of weapon, including ordinary objects like bottles or pool cues, any case I file against him would probably get thrown out instantly. It really would get thrown out instantly if say the extent of my injuries were a couple of cuts and bruises or a simple shiner. I'd also get some pretty disgusted looks from the cops and the fiscal too.
Conversely if I won the fight, his charges on me would likely stick.
Makes a good case for self policing IMO.
Rich, do you know the facts of the infamous McDonald's lawsuit?
If there is no gravity, how does one know it is upside down?Gary, does this mean that in space a computer server with something like the Lynx card and a solid state drive is required for high fidelity? Ground control to Major Tom, errrr.... Gary!
Thanks, Gary. Acutally, I knew the facts of the McDonalds case, and there are even more facts not listed in that link which, when considered by the jury, make the case against McDonalds even more. I'm just amused when people cite the McDonalds case as purported evidence of a frivilous lawsuit. That there are frivilous lawsuits is not disputed by anyone. Having stated that, there are plenty of remedies, both under federal and state law, for those who are ultimately found to be the victim of frivilous lawsuits. The fact of the matter is that the term *frivilous lawsuits* as it is usually bandied about in today's political rhethoric, is code used by politicians, usually republicans, who are out to protect big business.
Just because someone wins a lawsuit, does that prove the lawsuit wasn't frivilous? Coffee is brewed at 180 degrees. If I pour you a cup of coffee as soon as it is finished brewing, guess what the temperature is going to be. Ever drink coffee made from a French press? You heat water until it just starts to boil and that temperature is 212 degrees and then you pour the water into your French press. Think that coffee is hot? McDonalds nor anyone else who sells coffee ever intended for their customers to stick a cup of hot coffee between their legs. Accidents happen all of the time and some of them are preventable. Just because you make a poor decision and hurt yourself as a result doesn't mean it was someone else's fault that you made a poor decision. It's hard to protect against stupidity, but we do try in this country. That why we have warnings on hairdryers that say don't use in the shower or bathtub. And now we have warnings on coffee cups that say "Caution, contents are hot" because the selllers have to assume we are idiots and maybe we don't realize that we didn't order iced coffee. Bottom line is that it is a shame the woman burned herself, but it was her fault for making a very bad decision.
My favorite notice was on the package of a Halloween Wonder Woman costume we once bought for my daughter: "This product will not enable the wearer to fly."
the best decision she made was to hire a good attorney
Sure Steve. It's the American way. Anytime something bad happens to you, it can't be your fault. You find the person with the deepest pockets, find a shark in a suit who will take the case on a contingency basis, and go get 'em.
Well, the illustration on the bag showed her flying. Of course, they had the same denial on the Superman suit package.That IS funny. IIRC even wonder woman needed her invisible jet to fly!![]()
An excellent point. In a world of flow-soldered surface mount devices, even the most skilled (as in do it 40 hours/week for years), J-STD certifed techs experience a statistically significant amount of PWB damage during hand rework. Sometimes it's obvious, sometimes it's latent i.e. it's not discovered until CCA test. Either way, it ain't easy to fix.Several hundred parts seems like an awful lot of parts to replace. In order to safely remove parts from a circuit board requires skill and the right equipment so you don't damage or lift traces from the circuit board. All of the techs who work for me that do soldering/desoldering have at least 3 different J-standard soldering certifications. I wouldn't want some hack with a $10 soldering iron from Radio Shack touching my gear. You have to understand what temperatures to use for different components and have the right tools and the right skills to perform this type of work.
Presumably, Mr. S is J-STD 001 certified.
