My photo was sent to me today by Reinhard. I guess it's okay anyway if it can be added back.Here's a picture of the mk2 version. Notice the two grounds and also the "parking spots" for single coil mono. Maybe your picture is an old one?
434x434x154. Not small!These units are huge. Make sure it will fit in your rack depth wise.
I am only now finding out about the Thoress phono enhancer as I look for a further or new phono as 3 inputs would exceed my AR Ref 2. At 9300 euros and 6 inputs it would seem to be a veritable bargain and I'm surprised more don't use it unless it has shortcomings that I have not read about.
I"m looking for a musical phono, not one that is only blindingly resolving. Would the Thoress fit this bill?
That sounds like a pretty strong endorsement Mike!i owned the Thoress Enhancer for 2 months a few years back and was very impressed by the performance and by Reinhardt. a true pleasure to deal with. i recommend it highly. very musical and flexible. beautiful point to point wiring and build quality.
i only sold it because my Herzan active isolation used a SMPS (switch mode power supply) which caused noise, and it was sitting under my tt so could not move the Thoress far enough away from it.
now i have linear power supplies for my active isolation so it would not be an issue. i would consider buying it again.
What types of inputs do you need, i.e. what cartridges will you use?Would the Thoress fit this bill?
Right now I have a Ben LP-S, Ortofon Anna and Ikeda 9Gss. Could you elaborate about the aspects that might cause issues? I would expect other Lomc cartridges to be added later. ThanksWhat types of inputs do you need, i.e. what cartridges will you use?
The Thöress is very versatile, but it can't handle everything and especially not everything at the same time.
Ok, the LP-S has moderate output but very high impedance, but it will work very good. The Ikeda won't be a problem with moderate output and very low impedance. The Anna has very low output, you may need a SUT for that.Right now I have a Ben LP-S, Ortofon Anna and Ikeda 9Gss
Well, the Thöress has possibility for very high gain (something like 60dB, I'm not sure because it is not revealed), and it uses a cascoded pcc88 without feedback for active amplification.Could you elaborate
Dear Howie,So my question is, would this be an upgrade from an AR ref 2? How about ref 10?
Dear Howie,
If I remember correctly the Thoress gain is fixed. 62 db is no high. You could possibly have it customized to the level of gain you want but it will be fixed. In fact if you have tape you could even have him do one input for tape phono. For me gain matching is very important getting a good drive from a cart. Having a variable gain is definitely a plus to people who like to play different carts. Even my EMT phono is quite versatile, i still could not get a good matching with Red Sparrow and Grado Epoch. I had the Thoress in my system once a long time ago. It sounded nice. I also cannot recall how the loading can be adjusted.
Kind regards,
Tang
Guys - I haven't found any SET+horn owner of the IO. Both systems I heard it in, it's large stage, bass, muscle, dynamics, suited big speakers a lot. Any horn owners anyone knows with IO?
Straight from the horses's mouth. Gain on Thoress is 70db and not adjustable. Should be enough imho. Reinhard also sent me a few links. He really is amazingly responsive. Kudos. He strongly believed that matching to a tube preamp is preferable to SS.
On Thöress Phono Enhancer i assume.Gain on Thoress is 70db and not adjustable
On the input resistors:I also cannot recall how the loading can be adjusted.
On the Allnic, the internal SUTs, which have four gain settings, are actually very good (better than the ones in my previous EAR 912 - I was able to try back to back) but top quality externals like my Miyajimas can be better than the internals, and in the Miyajimas' case also offer more flexibility. I am keen at some point to try out one of the external Allnic head amps, though going from my own past experience I doubt it will be preferable to a good SUT. But I guess we'll see. Most Allnic owners will not feel short-changed at the SUT performance.
I had a few issues with the Thoress that left me thinking that it might suit some people but could never suit me. I did send a lengthy email to Reinhard explaining my reservations but he chose to argue with me rather than listen (bit of a German trait sadly) which is a shame as my needs as an owner of multiple, removable headshelll tonearms one of which is reserved solely for mono I think are far from unique and deserve a hearing.
Anyway - apologies for the length of what follows but I actually feel quite strongly about the Thoress:
1) It's not SUT friendly. Ok, there is a philosophical divide between people who like to amplify LOMCs all the way directly, and people who prefer SUTs or head amps. I'm very much in the SUT camp and use the Miyajima ETR-Stereo and ETR-Mono SUTs (but have also owned ones from Hashimoto, EAR, Music First, Kondo, AN-UK etc etc etc). I like to switch cartridges around, in particular to accommodate early and later mono which need different tip sizes. Really, you need SUTs for that sort of flexibility. Yes there were different gain and impedance settings on the different inputs of the Thoress, but for me it was too much of a pain to be swapping cables from input to input when changing headshells. Also the MM input in the dem unit I tried was far too high gain but I guess that's fixable if you pre-order.
2) No mono button or sensible mono option. Yes it's possible to faff with cables and mess around to make mono work, but it's not easy to use, and it all has to change again if you want to go back to stereo. There is no plug and play option for for mono and I had (ultimately) some serious hum problems that were a real downer for the demo I had. Maybe Reinhard has found a better workaround in the last year but I doubt it somehow.
3) No independently switchable inputs and outputs - this is really whats needed to address the above, you need the ability to have more than one input, and more than one output connected, independently switchable between. Not possible. Which led to many of the problems above.
4) Equalisation adjustment is non standard - I am used to having adjustable turnover and rolloff, the two dimensions that control the EQ curve, to give adjustability where a record uses non-RIAA EQ. But Reinhard insists on having three knobs, which don't relate directly to manipulating turnover and rolloff, instead operate like a tone control. I don't understand why he did this but it's impossible to dial up specific curves for specific labels, it's all done by ear. Seems like a totally daft way of doing it.
Anyway my conclusion was that the Thoress would be a reasonable option for someone who philosophically is happy with direct to MC amplification (personally I've never heard one that sounds better than a decent SUT but each to their own), uses a fixed cartridge in a fixed headshell on a single tonearm, and doesn't listen to mono. But if that's the target customer why all the complication? I just don't get it, it seems like the real needs of a multi-arm, multi cartridge, multi format (mono and stereo) user simply haven't been properly considered.
To be honest the Allnic has a few flaws too.
1) It has correctly implemented variable EQ (turnover and rollof) but this is limited to four steps for each, when you really need six each to be comprehensive for 78s (four is just about OK for early mono LPs). So it falls a bit short of being a proper archival phono stage.
2) The head amp in the H7000V seems to have insufficient gain to be practical at least with my low output, low impedance, low compliance choice of cartridges, is not adjustable for gain and needs resistors swapped inside to be adjustable for loading. For me it seems a bit pointless.
3) The presence of the head amp has a significant down side in that it's not possible to access the SUTs from both MC inputs - you are stuck with one MC input with SUTs, and the head amp on the other MC input. When ordering new prior to manufacture you can specify SUTs accessible from both and no head amp, but this is not possible to achieve retrospectively after manufacture. For all its four inputs (two MM, two MC) practical use of the MC inputs is consequently somewhat limited in practicality.
4) And of course - it has no mono button either, due to the dual mono design. However using the two possible output options (balanced and unbalanced, which are switchable), I was able to use balanced out for stereo, and fudge the mono issue, using one (obviously mono) output from the Miyajima mono SUT into one Allnic MM input, and a Y cable to provide two channel mono out of one side's unbalanced output, a solution that works extremely well sonically with no trace of hum. The only down side is that moving from stereo to mono and back again requires switching both the input to the phono stage, and the input to the preamp, but at least unlike the Thoress it can be done from the knobs on the system, there is no faffing about plugging and unplugging.
Ultimately though the the main reason I favoured the Allnic over the Thoress was that the Allnic sounded better ... it feels freer, less constrained, more musical, more natural than the Thoress which for all its high quality always sounded like hifi by comparison ...about what you'd expect from a tube/fet hybrid straight-MC phono stage with 70db of amplified gain (always a bad idea in my view, YMMV), compared to a decent SUT into a top qualify LCR MM input as with the Allnic. Also, compared to the Thoress, the Allnic's foibles were things I could live with or work around, rather than being complete show-stoppers.
Agree. And it should not be necessary.1) It's not SUT friendly. Ok, there is a philosophical divide between people who like to amplify LOMCs all the way directly, and people who prefer SUTs or head amps. I'm very much in the SUT camp and use the Miyajima ETR-Stereo and ETR-Mono SUTs (but have also owned ones from Hashimoto, EAR, Music First, Kondo, AN-UK etc etc etc). I like to switch cartridges around, in particular to accommodate early and later mono which need different tip sizes. Really, you need SUTs for that sort of flexibility. Yes there were different gain and impedance settings on the different inputs of the Thoress, but for me it was too much of a pain to be swapping cables from input to input when changing headshells. Also the MM input in the dem unit I tried was far too high gain but I guess that's fixable if you pre-order.
I understand Reinhards decision to keep all circuits clean.2) No mono button or sensible mono option. Yes it's possible to faff with cables and mess around to make mono work, but it's not easy to use, and it all has to change again if you want to go back to stereo. There is no plug and play option for for mono and I had (ultimately) some serious hum problems that were a real downer for the demo I had. Maybe Reinhard has found a better workaround in the last year but I doubt it somehow.
Yes, good point.3) The presence of the head amp has a significant down side in that it's not possible to access the SUTs from both MC inputs - you are stuck with one MC input with SUTs, and the head amp on the other MC input. When ordering new prior to manufacture you can specify SUTs accessible from both and no head amp, but this is not possible to achieve retrospectively after manufacture. For all its four inputs (two MM, two MC) practical use of the MC inputs is consequently somewhat limited in practicality.
I think this design decision by Reinhard comes from the fact that the standard eq time constants doesn't give you a flat response anyway, because that is dependant also on the record, cartridge and phono stage. Tons of factors may alter the signal.4) Equalisation adjustment is non standard - I am used to having adjustable turnover and rolloff, the two dimensions that control the EQ curve, to give adjustability where a record uses non-RIAA EQ. But Reinhard insists on having three knobs, which don't relate directly to manipulating turnover and rolloff, instead operate like a tone control. I don't understand why he did this but it's impossible to dial up specific curves for specific labels, it's all done by ear. Seems like a totally daft way of doing it.
